Dude2048
Script works from CLI but not from system scripts V7
Thu Jan 05, 2023 8:49 pm
When I create a script like below, in works like a charm in CLI but the "put" command stays empty when I run it from system scripts. Is this a V7.6 bug?
:interface monitor-traffic ether2 once do={:global bps $"rx-bits-per-second" }
:put $bps
eworm
Re: Script works from CLI but not from system scripts V7  [SOLVED]
Thu Jan 05, 2023 10:24 pm
You need to declare the variable first:
:global bps;
/interface monitor-traffic ether2 once do={
:set bps $"rx-bits-per-second" }
:put $bps
Dude2048
Thu Jan 05, 2023 11:30 pm
So stupid of me. I don't know why I missed this. Big thnx
rextended
Fri Jan 06, 2023 1:47 am
If you use correct syntax, is more easy.
Better call ":interface" as "/interface"
I do not think you need the bps variable globallly...
If the method support "as-value" you do not need to use more complex "do={}"
On CLI you must use { at the start and at the end } because each line do not keep local variables.
On script the start { and the end } are not needed.
ether2 is not one variable, but is one string, better use " "
There are a lot of things that still work even if written badly, but sometimes they give unexpected results,
and if one has gotten used to writing incorrectly, he can't even find the errors...
:local bps ([/interface monitor-traffic "ether2" once as-value]->"rx-bits-per-second")
:put $bps
Or for better structure the script for future mods:
:local iface "ether2"
/interface
:local tmparr [monitor-traffic $iface once as-value]
:local rxbps ($tmparr->"rx-bits-per-second")
:local txbps ($tmparr->"tx-bits-per-second")
:put "$iface bps RX $rxbps / TX $txbps"
Dude2048
Fri Jan 06, 2023 11:38 am
Thank you for the tips. I will try to better my life.
Users browsing this forum: slimmerwifi and 67 guests
