O1DMBFan
Registration Count not working with use of variable reference
Thu Jan 05, 2023 9:24 pm
Tweaking one of my scripts to include total wireless registration count and running count as it loops through the entire list for action. Running into an issue where referencing the interface name as a variable returns no results, while explicitly referencing it returns the proper results. Can't seem to figure out why.
######The following DOES work:######
:local totalWirelessInt
#Set total wireless registrations
:set totalWirelessInt [/interface wireless registration-table print count-only where name=wlan1];
:log warning message= ("Total Wireless Clients of Radio: " . $totalWirelessInt)
######The following DOES NOT work:######
:local wirelessNAME;
:set wirelessNAME "wlan1";
:set totalWirelessInt [/interface wireless registration-table print count-only where name=$wirelessNAME];
Thanks for your help!
rextended
Re: Registration Count not working with use of variable reference
Fri Jan 06, 2023 2:24 am
You have omitted RouterOS version, as usual.
Work???
Sure???
On registration-table do not exist "name" field, but only "interface" for wlan1. ("radio-name" is the description, if provided, of the remote wlan)
Using correct syntax and logic... is advised...
correct code
# example 1
:local totalWirelessInt [:len [find where interface="wlan1"]]
:log info "Total Wireless Clients of Radio: $totalWirelessInt"
# example 2
:local wirelessNAME "wlan1"
:local totalWirelessInt [:len [find where interface=$wirelessNAME]]
:log info "Total Wireless Clients of $wirelessNAME: $totalWirelessInt"
O1DMBFan
Fri Jan 06, 2023 11:17 pm
Thanks for your help, that's the advice I needed.
Cheers!
Users browsing this forum: alixviral and 51 guests
