telecomnetwork2022
Percentage IN PCC Load Balancd
Sat Jan 07, 2023 1:24 pm
So we have 2 line
wan 1= 200M
wan 2=50MB
Traffic = 50% from wan1 and 50% from Wan2
Need Edit Rule to set load balance 70% from Wan 1 and 30 Form Wan 2
THANK
Current config
add action=mark-connection chain=prerouting dst-address-type=!local \
new-connection-mark=WAN_CON_1 passthrough=yes per-connection-classifier=\
both-addresses-and-ports:2/0 src-address=192.168.88.0/24
new-connection-mark=WAN_CON_2 passthrough=yes per-connection-classifier=\
both-addresses-and-ports:2/1 src-address=192.168.88.0/24
add action=mark-routing chain=prerouting connection-mark=WAN_CON_1 \
new-routing-mark=ROUTING1 passthrough=yes src-address=192.168.88.0/24
add action=mark-routing chain=prerouting connection-mark=WAN_CON_2 \
new-routing-mark=ROUTING2 passthrough=yes src-address=192.168.88.0/24
msatter
Re: Percentage IN PCC Load Balancd
Sat Jan 07, 2023 1:35 pm
66% = 1/3->1 2/3->1 3/3->2
telecomnetwork2022
Sat Jan 07, 2023 1:56 pm
thats wrong bro
So good
why is 3/1 3/2 3/3
why not 3/0 3/1 3/2
can you help me to write the addistional rule i need
msatter
Sat Jan 07, 2023 5:19 pm
Even simpler: 1/3 goes to two and the rest goes to one.
You so only need one PCC line that marks traffic for routing2 and the rest you just mark for routing1 as long it is not marked earlier for routing2.
both-addresses-and-ports:3/0 src-address=192.168.88.0/24
connection-mark=!WAN_CON_2 new-connection-mark=WAN_CON_1 \
Bye
chechito
Sat Jan 07, 2023 7:54 pm
Wan1 5/0
Wan1 5/1
Wan1 5/2
Wan1 5/3
Wan2 5/4
Using PCC
msatter
Sat Jan 07, 2023 10:30 pm
@chechito: really? Secondly, that is 80:20
Simpler, 5/4 to Wan2 what is left to Wan1.
Do you now get, how it can work?
Bye
telecomnetwork2022
Sat Jan 07, 2023 11:07 pm
wich the correct answer??
msatter
Sun Jan 08, 2023 1:08 am
You can be the judge on that.
anav
Re: Percentage IN PCC Load Balancd  [SOLVED]
Mon Jan 09, 2023 3:05 pm
Chechito had the right idea actually just didnt take it far enough.
WAN2 - 7/0
WAN2 - 7/1
WAN1 - 7/2
WAN1 - 7/3
WAN1 -7/4
WAN1 - 7/5
WAN1 - 7/6
To use Msatters cute but not fully explained shortcut..................
both-addresses-and-ports:7/0 src-address=192.168.88.0/24
both-addresses-and-ports:7/1 src-address=192.168.88.0/24
Users browsing this forum: Bing [Bot], pav5, shahzaddj1 and 170 guests
