kubah
WifiWave 2 problem - disconnect
Sat Jan 07, 2023 9:57 pm
Hello, I have problem - my hap ax3 after few hours lost and disconnect wifi.
After that I need to connect via cable and disable & enable wifi.
Mikrotik is setting using quik set:
# jan/07/2023 20:39:49 by RouterOS 7.6
# software id = X7H7-2THF
# model = C53UiG+5HPaxD2HPaxD
# serial number = HDF08MFKFM8
add admin-mac=48:A9:8A:05:23:8F auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=64:EE:B7:20:82:2D
/interface wifiwave2
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Poland .mode=ap .ssid=hAPax3-5GHz disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Poland .hide-ssid=no .mode=ap .ssid=hAPax3-2GHz \
    disabled=no security.authentication-types=wpa2-psk,wpa3-psk
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/interface detect-internet
set detect-interface-list=all
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop everything else not coming from LAN" in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
    icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
    ipsec-esp
/system clock
set time-zone-name=Europe/Warsaw
/tool mac-server
/tool mac-server mac-winbox
what could be the problem?
Users browsing this forum: jaclaz, unhuzpt and 97 guests
