tonny
no cloud update and non-hexadeciman serial number
Mon Jan 09, 2023 9:39 am
Hei,
I've got three RB4011 that won't update ddns in IP/CLOUD. The config is correct, i've tried it on other routers. They run on version 6 long-term
Also ran a packet capture on UDP/15252 and traffic goes out and gets answered. But no update of time not device cloud ddns name
The thing is/might be that their serial number no longer matches the mac adress.
(all digits are replaced with '0')
HD00000M0SV
HD000F0GK0N
HD000DKQC0P
Anyone with the same experience ??
Znevna
Re: no cloud update and non-hexadeciman serial number
Tue Jan 10, 2023 7:32 am
Serial numbers never matched the MAC.
tonny
Tue Jan 10, 2023 9:14 am
you're right. but at least the looked like a mac address
rextended
Wed Jan 11, 2023 12:33 pm
I never see (on MikroTik products from 2007+) a serial number that match the MAC address, and the DNS name can contain any ascii-7bit letters and numbers.
(probably can be forced on x86/64 and CHR version, setting on the VM interface one MAC address that resemble the x86/64 Software-ID or the CHR System-ID)
Users browsing this forum: CHUPAPEE, faxxe, holla29, noyo and 214 guests
