Hi.
I have two same routers (CCR1016), one of these is configured and that contains OVPN settings and certificates, I will to set second router same at first, but after restore backup OVPN connection not working, after run rsc from first router and import certificates, OVPN not working. What is the right way for this? When I import the CA, Server and user certificate the CA column is blank and they are flagged only with K, not with KI... When restore the backup, certificates is flagged only with "I" but not with KI... Can you help me how to move all certificates from one to other router and to working it?
