Corné
CSS610-8P-2S+IN trusted interfaces disable bug?
Mon Jan 09, 2023 6:21 pm
Default configuration the CSS610-8P just works when connected to a router (DHCP) as all trusted ports are checked.
System > DHCP & PPPoE Snooping > Trusted Ports
However when changing anything on the system page for example the hostname the trusted ports become unchecked and therefore DHCP packets are dropped. DHCP lease will timeout and devices will lose the (L3) connection L2 remains. Manually enabling the trusted checkmarks and applying the changes does not work.
Resetting the switch to default is the only way to enable the trusted interfaces.
Current Installed Version 2.15 (built at Thu Mar 10 2022 06:58:58 GMT+0000 (Coordinated Universal Time))
gabacho4
Re: CSS610-8P-2S+IN trusted interfaces disable bug?  [SOLVED]
Mon Jan 09, 2023 10:31 pm
You're gonna wanna see viewtopic.php?t=188407#p962169 and look for the link to SWoS lite 17.1rc1.
Corné
Thu Jan 12, 2023 5:44 pm
Thanks for the ref. link.
Users browsing this forum: sakke42 and 9 guests
