patelroshan051
Mikrotik Pro not working properly on Android 13
Mon Jan 09, 2023 10:21 pm
I am using RBMQS to power up and access mikrotik antennas on phone. It was working fine until recently. I have upgraded android 13 on my phone and suddenly Mirkotik app started working inconsistent. I have uninstalled and installed app but it didn't helped. The problem I'm facing is most of the time screen stuck on downloading plugins. Even if it passes that the app itself shows no interface or any other settings. I tried 3 different phone out of them 2 was running on Android 13 and 1 was running on Android 10. It works fine on Android 10 only latest Android is having issue.
satman1w
Re: Mikrotik Pro not working properly on Android 13
Wed Jan 11, 2023 2:52 pm
you will ha ve to decide which is more important... to have a latest version of android, or working app...
anav
Wed Jan 11, 2023 5:54 pm
Get an iphone, works great. :-)
gabacho4
Wed Jan 11, 2023 7:25 pm
Works just fine for me on my Pixel 7 Pro. No functionality issues at all and I can actually launch a tik terminal unlike anav and his precious iPhan. 😀
anav
Wed Jan 11, 2023 7:42 pm
No idea what you mean by launch tik terminal, I am intrigued?
gabacho4
Wed Jan 11, 2023 7:47 pm
On Android, the Mikrotik app has the ability to launch a terminal/CLI for config or other purposes. On iPhone that feature does not exist because Apple decided it allowed too much system access or something. Apple restricts access to a number of data sources or features that Android does just fine. Eat your heart out llama.
optio
Long time Member
Long time Member
Wed Jan 11, 2023 8:06 pm
Regarding terminal feature on iOS app, it's not missing because of iOS limitation, terminal emulation must be handled in different way than on Android so probably this why is not implemented. For terminal on iOS I'm using Prompt 2 app, connecting to ROS over ssh.
gabacho4
Wed Jan 11, 2023 8:19 pm
Regardless of cause, the iOS functionality is limited compared to Android's. I tried the iPhone out and got tired of such limitations across a number of capabilities and tools that just work on Android. So back to Android it is for me.
Users browsing this forum: Bing [Bot] and 142 guests
