Hi all!
For a customer I have set up Capsman using ROS 6.49.7, RBM33G as controller and 3x cAP ac as caps, 2.4 and 5 GHz (40 Mhz), clear channel. Local forwarding.
He is hooking up approx 40 pcs Chromebooks at a time to do some updates/SSD erasing and complains that in between wireless is slow, for instance loading a website or downloading a script, even when bandwidth usage is low.
This setup replaces a previous installation based on Ubiquiti, reported to be running smoothly all the way...
Capsman controller CPU is low, connection is 200Mbps fiber so total capacity is no bottleneck.
For the time being, due to AP positions, maybe 20-30 of the Chromebooks are on the same AP, all of them support 5GHz and connects to 5GHz.
Signal is all in the -45 to -60 range, good uplink but rather moderate uplink, typical 120 Mbps or so.
Have tried to disable 5GHz but same happens when on 2.4, doing anything against the internet on any of the chromebooks keeps the connection lagging
So what can possibly be done to improve performance?
Any practical limitation on number of clients on an AP using CapsMan?
