scube
Configuration for QSFP+ Breakout to 4xSFP+
Wed Jan 11, 2023 12:29 pm
Hi everyone!
I connected a CRS354 with a QSFP+ port to a CCR2004 with 4xSPF+. I use the mikrotik breakout cable Q+BC0003-S+.
So far the link itself works fine. I disabled autonegoation on the qsfpplus1-1 to qsfpplus1-4 interfaces, but left autonegoation enables on the 4 SFP+ ports.
What I am now wondering and did not find an answer to is: Do I need to create a bond to fully use the 40Gbps or can I leave it as I have now?
Thanks for your advice!
chechito
Re: Configuration for QSFP+ Breakout to 4xSFP+
Wed Jan 11, 2023 7:18 pm
be aware a bonding interface on 2004 will run on software, not hardware accelerated
scube
Tue Jan 17, 2023 7:36 pm
Yes, thank you for that information (I actually was not aware of that).
Has anyone the answer to the bonding question? Is it actually necessary? (All tough, I assume I won't be anywhere near the 40Gbit)
scube
Mon Feb 06, 2023 2:08 pm
Bump as I do not have an answer to my original question.
Using a breakout cable (regardless of the involved switches/routers): Is it enough to just have the links online or do I have to configure a Bond?
scube
Fri Mar 31, 2023 7:31 pm
Anyone here that might be able to answer that?
Users browsing this forum: No registered users and 64 guests
