taske
Wifi router behind mikrotik
Wed Jan 11, 2023 12:39 pm
Hello everyone,
straight up beginner here. I recently replaced my TP Link wireless router with a mikrotik hex. Seeing as hex doesnt have wifi capabilities i was wondering if i could keep using the tp-link router purely as an access point and how i would go exactly setting this up.
thanks!
anav
Re: Wifi router behind mikrotik
Wed Jan 11, 2023 5:23 pm
Sure, get the mac address of the TP Link, decide on the hex what IP you want to give it, then add it manually on the hex via dhcp leases.....
Go to your TPLINK put that IP address as a fixed IP address on the TPLink and you will be up and running.
What model of TP LINK ( probably not vlan capable )..........
taske
Sat Feb 11, 2023 6:07 pm
hey, sorry for the late response, i just got around to this.
So mikrotik is working fine, i connected it from eth2 to WAN port on TP link. I can see it was given an IP via winbox table but i cant connect to it anymore. IP scanner finds it aswell on the given ip but im getting no response from the router.
anav
Sat Feb 11, 2023 7:40 pm
Find the mac address of the TPLink on the hex.
Set the IP to static in the DHCP lease.
Then go to the tplink and ensure it gets a fixed wanip......... does it have an access point mode??
Moba
Sun Feb 12, 2023 12:35 am
Use the AP mode, if available, on the TP-Link.
Users browsing this forum: roemer, seriosha, unhuzpt and 33 guests
