justwhite
RB4011iGS+RM power consumption
Wed Jan 11, 2023 6:07 pm
Hello!
The documentation RB4011iGS+RM says that power consumption is:
Max power consumption 33 W
Max power consumption without attachments 18 W
But what does "without attachments" mean, does it mean only PoE/USB/SFP+, or does connected ethernet also affect consumption?
DC 12V 2A worked not stable and with errors.
satman1w
Re: RB4011iGS+RM power consumption
Wed Jan 11, 2023 6:20 pm
...connected ethernet does not consume power...
onnoossendrijver
Wed Jan 11, 2023 7:40 pm
Actually it does.
satman1w
Wed Jan 11, 2023 9:12 pm
Actually it does.
Yes, actually it does, but actually it almost doesn't matter
I was expecting some specialist to appear...
When you're already full of wisdom, then why did not you tell us how much power is consumed on the ethernet port?
It is clear to everyone that there is some consumption, but it is also clear that it is negligible compared to the total consumption of the CPU and other electronics, especialy to the PoE OUT
The consumption of the gigabit port is between 0.25 and 0.5W, which for the 4011 means 5W if all ports work at maximum.
Do you think it's worth mentioning the total consumption of 33W?
onnoossendrijver
Wed Jan 11, 2023 9:36 pm
Calm down...
A RB4011 without any attachments is doing 7.5 watt on my desk, not 33.
satman1w
Wed Jan 11, 2023 10:35 pm
with CPU at 0% load...of course
chechito
Wed Jan 11, 2023 10:50 pm
i think you are at the lower edge of supported voltages, i think is better to stick with 24volts for PoE and at least 18-19volts on jack for reliable operation
if you are trying a 12volt adapter, normal voltage drop because rb4011 can ramp up to 1.5 amp load this can easily get you close to 11-10 volts, this puts you below spec
holvoetn
Wed Jan 11, 2023 11:18 pm
Max Power WITH all POE attached is 33W. No more. E.g. add 2 time cap AC and you may already have trouble (13W for each at least, 24W max, times 2 = 26W - 48W)
Max power with no POE attached to it, only normal ethernet (disregarding several digits after the comma) = 18W
Sitting on a desk doing nothing is less :lol:
Users browsing this forum: No registered users and 38 guests
