Below is my network diagram,
After CRS112 Transparent OLT is working Fine but can't seen to work the 2nd OLT as that olt can only take VLAN334 but I have tried everything but can't connect that OLT via VLAN
please Help
I hope those OLTs are not connected to same physical port of CRS112 (situation digram can be understood as if they are).After CRS112 Transparent OLT is working Fine but can't seen to work the 2nd OLT as that olt can only take VLAN334 but I have tried everything but can't connect that OLT via VLAN
Both OLTs are on different portI hope those OLTs are not connected to same physical port of CRS112 (situation digram can be understood as if they are).
# jan/12/2023 19:28:32 by RouterOS 6.49
set [ find default-name=ether1 ] name=ether1-MGMNT
set [ find default-name=ether2 ] name=ether2-OLT1
set [ find default-name=ether3 ] name=ether3-OLT2
set [ find default-name=ether4 ] name=ether4-Input
set [ find default-name=ether5 ] name=ether5
set [ find default-name=ether6 ] name=ether6
set [ find default-name=ether8 ] poe-out=off
set [ find default-name=sfp9 ] name=sfp9
set [ find default-name=sfp10 ] name=sfp10
set [ find default-name=sfp12 ] auto-negotiation=no
add name=VlanBridge vlan-filtering=yes
/interface vlan
add interface=ether3-OLT2 name=vlan334 vlan-id=334
add name=WAN
add name=LAN
add bridge=VlanBridge interface=ether3-OLT2 pvid=334
add bridge=VlanBridge interface=ether2-OLT1
add bridge=VlanBridge interface=ether4-Input
add address=104.148.144.6/27 interface=ether1-MGMNT network=104.148.144.0
add address=10.22.22.1/24 disabled=yes interface=VlanBridge network=\
10.22.22.0
set servers=8.8.8.8
add distance=1 gateway=104.148.144.1
I am quite new in networking and routerOS, Can you please let me know How can I achieve that?Conceptually you want to have ether3 tagged outside of switch and untagged inside the switch. Which is the other way around from what usually is (tagged inside device, untagged outside ... that's where PVID comes into play). I'm not sure if your problem can be solved by settings on ether3 port only, could be you'll have to set same VLAN ID on all of involved switch ports (from config posted I assume that's ether2, ether3 and ether4) ... with PVID set on untagged ports (ether2 and ether4) and keeping port ether3 tagged.
add name=bridge1
/interface vlan
add interface=ether3 name=vlan334 vlan-id=334
add name=WAN
add name=LAN
add bridge=bridge1 interface=vlan334
/interface bridge vlan
add bridge=bridge1 tagged=vlan334 vlan-ids=334
