bramko
Winbox close connection in a loop
Thu Jan 12, 2023 4:45 pm
Hi i try to search for this issue , but didn’t found anything. I have new in box hap ac2 and when i start it i was able to access it with ios app MikroTik. But after I switched it off to take it to another place wifi disappeared so I decided to reset it.
Now when i try using Winbox it connects but connection is closed after 3-4 seconds and this repeats in a loop. I can provide a video of what is happening . I also did netinstall but no result.
Please advise what to do here is video https://youtube.com/shorts/hRC_cWWaC74?feature=share
k6ccc
Re: Winbox close connection in a loop
Fri Jan 13, 2023 5:19 pm
Let's split this in half. Can you connect a computer to the router and eliminate the phone, the phone app, and however it is connected as a potential problem.
bramko
Tue Jan 17, 2023 10:44 am
Hi yes i can connect computer but connection is alive only 5 seconds , then it reconnect in a loop because i am selecting auto reconnect. It throws me out of new window each 5 seconds, so nothing can do. I try on several laptops and pc’s same thing. I was thinking the program is crashing
nichky
Tue Jan 17, 2023 11:16 am
bugarce , what the CPU showing?
are u running any dynamic routing protocols?
bramko
Tue Jan 17, 2023 11:50 am
it's showing to change password, then window is closing automatically . If i click with mouse on window holding it it stays and when i release left click it closes again, time interval of opening and closing is identical in a loop. device is brand new just open and trying to configure it
nichky
Tue Jan 17, 2023 12:12 pm
can u get access via mac-add?
bramko
Tue Jan 17, 2023 12:15 pm
yes i can and it connects but just for 3-5 seconds then it throws me out of the window
nichky
Tue Jan 17, 2023 12:33 pm
what is the version on the winbox?
bramko
Wed Jan 18, 2023 7:15 am
It was 7.6 Now updated to 7.7, somehow with 4-th laptop i try and with usb-lan adapter it succeeded and now it’s working . Or because of update or for some other reason.
Thanks to everyone.
Users browsing this forum: No registered users and 42 guests
