myrddin
Configuration help
Thu Jan 12, 2023 9:19 pm
Network Diagram
https://drive.google.com/file/d/1cqJSt3 ... sp=sharing
I hope the image goes through. tinypic is no more, and it wouldn't load as an attachment to this post.
Export
# jan/12/2023 10:15:27 by RouterOS 7.5
# software id = HJND-FS5T
# model = CCR2004-1G-12S+2XS
# serial number = XXXXXXXXXXX
add name=lan_bridge protocol-mode=none
add disabled=yes name=wan_bridge
set [ find default-name=sfp-sfpplus1 ] name=1_faerun rx-flow-control=auto \
    tx-flow-control=auto
set [ find default-name=sfp-sfpplus2 ] name=2_magetower rx-flow-control=auto \
set [ find default-name=sfp-sfpplus11 ] auto-negotiation=no name=\
    11_wap_upstairs rx-flow-control=auto tx-flow-control=auto
set [ find default-name=sfp-sfpplus12 ] auto-negotiation=no name=12_isp \
set [ find default-name=ether1 ] name=management rx-flow-control=auto \
set [ find default-name=sfp-sfpplus3 ] disabled=yes
set [ find default-name=sfp-sfpplus4 ] disabled=yes
set [ find default-name=sfp-sfpplus5 ] disabled=yes
set [ find default-name=sfp-sfpplus6 ] disabled=yes
set [ find default-name=sfp-sfpplus7 ] disabled=yes
set [ find default-name=sfp-sfpplus8 ] disabled=yes
set [ find default-name=sfp-sfpplus9 ] disabled=yes
set [ find default-name=sfp-sfpplus10 ] disabled=yes
set [ find default-name=sfp28-1 ] disabled=yes
set [ find default-name=sfp28-2 ] disabled=yes
add name=lan
add name=wan
add name=lan_pool ranges=192.168.5.10-192.168.5.254
add address-pool=lan_pool interface=lan_bridge lease-time=1d name=lan_dhcp
/port
set 0 name=serial0
set 1 name=serial1
add bridge=wan_bridge disabled=yes interface=12_isp
add bridge=lan_bridge interface=1_faerun
add bridge=lan_bridge interface=2_magetower
add bridge=lan_bridge interface=11_wap_upstairs
/ip settings
set accept-source-route=yes ip-forward=no rp-filter=strict
/ipv6 settings
set disable-ipv6=yes
add interface=lan_bridge list=lan
add interface=12_isp list=wan
add address=192.168.5.1/24 interface=lan_bridge network=192.168.5.0
/ip dhcp-client
add interface=12_isp use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.5.100 client-id=1:98:b7:85:0:2a:cd mac-address=\
    98:B7:85:00:2A:CD server=lan_dhcp
add address=192.168.5.0/24 gateway=192.168.5.1 netmask=24
set servers=8.8.8.8
add action=masquerade chain=srcnat out-interface-list=wan
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
/system clock
set time-zone-name=America/New_York
What I'm trying to do
I'm trying to set up a LAN consisting of a server, desktop, and a wAP.
My problem
I can connect all the server, desktop, and wAP to the LAN DHCP and get valid IPv4 addresses for each device. However, when I ping 8.8.8.8 from the desktop I am unable to receive any packets back. I get the same result if I ping www.ibm.com. When I go into WinBox and ping from the terminal everything works as expected. I am able to ping other devices on the LAN, like the server, and receive a response. Can someone help me figure out what I am missing in my configuration that will let my LAN devices see out to the WAN.
Thank you in advance for any help you can give.
tomislav91
Re: Configuration help
Thu Jan 12, 2023 10:50 pm
Network Diagram
Export
add name=lan
add name=wan
/port
set 0 name=serial0
set 1 name=serial1
/ip settings
/ipv6 settings
/ip dhcp-client
set servers=8.8.8.8
/ip service
/system clock
My problem
i can't see ip route export?
myrddin
Thu Jan 12, 2023 11:35 pm
I generated the export with:
   export hide-sensitive file=ccr2004.export
Perhaps IP routes are what I am missing. I'll check tonight when I get home.
biomesh
Long time Member
Long time Member
Re: Configuration help  [SOLVED]
Fri Jan 13, 2023 1:38 pm
Under /ip settings you have ip-forward=no. If you want the router to route packets between networks that needs to be set to yes.
myrddin
Sat Jan 14, 2023 6:36 am
Thank you both for your help! The extra sets of eyes were incredibly useful.
I checked the IP routes and they were there, having been generated by the DHCP server and client. I have no idea why they didn't get exported though.
It came down to me having missed that the "ip-forward" in the "ip -> settings" was set to "no". Once I toggled that, everything worked great.
Thank you again for the help!
mkx
Sat Jan 14, 2023 11:34 am
Export command shows things that were explicitly configured (so it's really handy when troubleshooting problems with configuration). Dynamic stuff (such as IP address and routes, obtained by DHCP client, or leases of DHCP server) are not though. So when assessing router's state, it's vital to use also print command which displays running values (as opposed to configured values) - output format is different and to many it's less readable. Generally it has two verbosity levels, to get additional details run print detail.
There's third command which sometimes comes handy: monitor. Not every object in ROS has it though.
Users browsing this forum: No registered users and 49 guests
