Marshsu
RB2011 want to enable ipv6
Fri Jan 13, 2023 3:56 am
My router is RB2011 with ROS 7.6.
And I want to enable ipv6 on it, after search the internet, I do things below:
After that, I can see the ipv6 address-list as address-list.jpg, but my PC connect to rb2011 without ipv6 ip address.
Then search the internet again, somebody said need disable IGMP snooping in bridge-local that I defined in address.jpg, I do it, and the ipv 6 address showed additional entry on it, and my pc will has the ipv6 ip address. see address-list-2.jpg.
But after I power off the RB2011 and power on again, the address-list-2.jpg will change back to address-list.jpg, the additional entry was gone, and the pc without ipv6 ip again!
Any suggestion about it?
tdw
Re: RB2011 want to enable ipv6
Sat Jan 14, 2023 4:07 am
Random blogs and videos on the Internet are often incomplete, less than optimal, or just wrong. 'Managed Address Configuration' is incorrect, it should only be enabled if you have a DHCPv6 server. 'Add Default Route' is incorrect but sometimes works, using Router Advertisments is the correct method.
Screenshots do not show everything, post the output of /export or /ipv6 export at a minimum after redacting serial number, any public IP addresses, etc.
Marshsu
Sat Jan 14, 2023 6:00 am
Thanks. Here is the /ipv6 export
[admin@MikroTik] /ipv6> export
# jan/14/2023 11:54:53 by RouterOS 7.7
# software id = C50F-KI26
# model = RB2011UiAS-2HnD
# serial number = ---------------
/ipv6 dhcp-server
add address-pool=ipv6pool disabled=yes interface=bridge-local name=DHCPv6
/ipv6 dhcp-server option sets
add name=DHCPV6
/ipv6 address
add address=::4e5e:------- eui-64=yes from-pool=ipv6pool interface=bridge-local
/ipv6 dhcp-client
add interface=PPPoE-WAN-1 pool-name=ipv6pool request=prefix use-peer-dns=no
/ipv6 firewall filter
add action=accept chain=input comment="Accept DHCPv6-Client prefix delegation" dst-port=546 protocol=udp src-address=fe80::/16
/ipv6 nd
set [ find default=yes ] disabled=yes hop-limit=64 mtu=1496 ra-interval=20s-1m
add hop-limit=64 interface=bridge-local mtu=1496 ra-interval=20s-1m
/ipv6 settings
set max-neighbor-entries=8192
tdw
Sat Jan 14, 2023 5:09 pm
Firstly for the Mikrotik to pick up the default route you need
/ipv6 settings
set accept-router-advertisements=yes
Note the learnt default route does not appear in the IPv6 routing table.
I'm not sure why you have non-default ND parameters, perhaps from earlier versions. The current defaults for those are hop-limit=unspecified mtu=unspecified ra-interval=3m20s-10m
The DHCP server and options / option sets are not required unless you wish client devices to request non-address information such as DNS servers, etc. This is done when ND other-configuration=yes
Other than that there isn't anything obvious. Looking back at the images the address which disappears is the link-local address, I suspect it is a display artefact which incorrectly hides them when another dynamic address exists.
Users browsing this forum: Amazon [Bot], Bing [Bot], MatoZ, sas2k, smirgo and 103 guests
