va77
Thousands of routes
Sat Jan 14, 2023 5:01 am
Hi all, is it possible somehow to add about 14000 routes ?
Idea is devide the routes between two interfaces, routes (IP addrs) to first interface belongs to one country, rest of routes of all other countries - through the second interface.
I created a text file with ~14k commands "/ip route add dst-address=..." (which belong to one country), but seems it's not possible to execute into terminal.
Will be happy to get any reply.
BartoszP
Re: Thousands of routes
Sat Jan 14, 2023 11:54 am
Upload it as rsc file and execute it with
/import file=thenameofuploadedfile
Read this to prepare import file properly
viewtopic.php?p=606832#p606832
pe1chl
Sat Jan 14, 2023 12:06 pm
Before you try to do this using static routes, first consider to use a routing protocol like BGP.
Amm0
Sat Jan 14, 2023 12:52 pm
This problem screams BGP. But would BGP actually be more performant if the routes are fixed? I like to think so, but not sure myself.
I guess the alternative is a firewall address-list with mange rule to set/mark routing... but have to imagine that be slower than BGP or even static routes :import by script.
pe1chl
Sat Jan 14, 2023 1:22 pm
The advantage of using BGP is that you do not need to maintain this list of routes (which will change over time) in all the routers.
You will only need to feed them in from an external source.
va77
Fri Jan 20, 2023 1:25 am
Thanks to all, I imported the file with commands and run it from terminal. Proccess took 25 minutes, but my old MikroTik with 1 cpu core and 64 mb ram deal with 14k routes without any issues. 15-20 mbps through l2tp tunnel+ipsec, great use for an old router.
Users browsing this forum: tangent and 28 guests
