wsantos
hap ax3 using to much memory with default configuration
Sat Jan 14, 2023 1:02 pm
I've 2 routers at home RB750Gr3 and C53UiG+5HPaxD2HPaxD (hap ax3) and here is the memory usage I've right now, my ax3 is brand new nothing installed, RB750Gr3 already has some small firewall rules 2 wireguard tunnels and an address list with 926 entries:
RB750Gr3, 195.5MB of 256MB -> ~24% usage.
C53UiG+5HPaxD2HPaxD, 682.8MB of 1024GB -> ~33% usage.
Is there an explanation for that? how can I check what is eating the memory? remember my hap ax3 is brand new.
holvoetn
Re: hap ax3 using to much memory with default configuration
Sat Jan 14, 2023 5:03 pm
Wifiwave2-AX package will most likely be the culprit. Wave2 is known to require quite a bit of memory, AX more so.
HEX doesn't have wifi so no wave2.
But I am not sure how to get the details on memory usage to make that a proven statement.
Logically thinking: there is a reason why they put 1Gb of memory in that device vs 256Mb on AC3 ... that's not only because that's a cheaper size. AX-drivers will have something to do with it as well.
I'll wait here with you for an answer.
As a workaround, disable the wifi interfaces on AX3, reboot and see what happens with memory usage.
wsantos
Sat Jan 14, 2023 5:37 pm
I had to disable the package and now I have 784MB free, I was expecting to have ~900MB tbh something else is also eating memory seems like
holvoetn
Sat Jan 14, 2023 5:46 pm
Very odd.
On my AC3 (256Mb memory), incl some firewall rules, DHCP server, filtering, VLANs, routing rules and wave2 active, I still have139Mb free.
Otherwise post your config so we can have a look what the default looks like.
/export file=anynameyouwish ( minus router serial # and any public WANIP information )
Post config between [ code] quotes.
wsantos
Sat Jan 14, 2023 5:50 pm
Very odd.
There is no config, it's a brand-new router, I noticed the memory usage and decided not configure before identifying what was eating the memory
Znevna
Sat Jan 14, 2023 6:27 pm
You can't compare like that, totally different SoCs underneath.
wsantos
Sat Jan 14, 2023 7:27 pm
True ax3 is an arm 64bits but would be nice to understand the memory usage.
Rox169
Sun Jan 15, 2023 9:39 pm
this is very useless topic...almost 700MB free RAM is not enough for you?
wsantos
Mon Jan 16, 2023 12:57 am
It's not for the containers I want to use and the main reason is to understand how to profile memory, not useless if we can understand how to do it.
Users browsing this forum: complexxL9, panzermaster18 and 202 guests
