Mehuge
hAP ax3 ether1 for wan?
Sat Jan 14, 2023 2:34 pm
Been following viewtopic.php?t=143620 and building a config based on the guest example adapting it to also include a work isolated network.
This config: download/file.php?id=46392
I notice it is using ether1 for wan.
# Yellow WAN facing port with IP Address provided by ISP
/ip address add interface=ether1 address=a.a.a.a/aa network=a.a.a.0
add interface=ether1     list=WAN
Isn't ether1 the 2.5gbit PoE port on the hAP ax3?
Would it be better to use ether5 as the wan interface leaving ether1 available for LAN?
is it a simple as changing the config to reference ether5 instead of ether1 or would additional config be required?
holvoetn
Re: hAP ax3 ether1 for wan?
Sat Jan 14, 2023 4:59 pm
Default config on most ROS devices is indeed to have eth1 as WAN but you can change it as you wish.
Users browsing this forum: Bing [Bot], Google [Bot], karlisi and 129 guests
