AAw
False Active Sessions!
Sat Jan 14, 2023 2:55 pm
Hi there!
I have a problem with user manager which is in an external CHR with v6.49.6
I always find false active sessions in user manager while they are not active anymore.
I have tried some scripts but they not work.
I need a script that close (not remove if possible) these active sessions.
anyone have the right script please?
rextended
Re: False Active Sessions!
Sat Jan 14, 2023 5:57 pm
since only you know what are "false" or not, use your hand.
AAw
Sat Jan 14, 2023 9:53 pm
What the whole preceding post was quoted for? Is it a problem to just use "Post Reply" button?
I'm doing it by hand now. but the script with scheduler will do it for me with ease! :D
Reason: removed excessive quotting of preceding post; be wise, quote smart, save network traffic
rextended
Re: False Active Sessions!  [SOLVED]
Sat Jan 14, 2023 11:49 pm
:global datetime2epoch do={
    :local dtime [:tostr $1]
    /system clock
    :local cyear [get date] ; :if ($cyear ~ "....-..-..") do={:set cyear [:pick $cyear 0 4]} else={:set cyear [:pick $cyear 7 11]}
    :if (([:len $dtime] = 10) or ([:len $dtime] = 11)) do={:set dtime "$dtime 00:00:00"}
    :if ([:len $dtime] = 15) do={:set dtime "$[:pick $dtime 0 6]/$cyear $[:pick $dtime 7 15]"}
    :if ([:len $dtime] = 14) do={:set dtime "$cyear-$[:pick $dtime 0 5] $[:pick $dtime 6 14]"}
    :if ([:len $dtime] =  8) do={:set dtime "$[get date] $dtime"}
    :if ([:tostr $1] = "") do={:set dtime ("$[get date] $[get time]")}
    :local vdate [:pick $dtime 0 [:find $dtime " " -1]]
    :local vtime [:pick $dtime ([:find $dtime " " -1] + 1) [:len $dtime]]
    :local vgmt  [get gmt-offset]; :if ($vgmt > 0x7FFFFFFF) do={:set vgmt ($vgmt - 0x100000000)}
    :if ($vgmt < 0) do={:set vgmt ($vgmt * -1)}
    :local arrm  [:toarray "0,0,31,59,90,120,151,181,212,243,273,304,334"]
    :local vdoff [:toarray "0,4,5,7,8,10"]
    :local MM    [:pick $vdate ($vdoff->2) ($vdoff->3)]
    :local M     [:tonum $MM]
    :if ($vdate ~ ".../../....") do={
        :set vdoff [:toarray "7,11,1,3,4,6"]
        :set M     ([:find "xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC" [:pick $vdate ($vdoff->2) ($vdoff->3)] -1] / 2)
        :if ($M>12) do={:set M ($M - 12)}
    :local yyyy  [:pick $vdate ($vdoff->0) ($vdoff->1)] ; :if ((($yyyy - 1968) % 4) = 0) do={:set ($arrm->1) -1; :set ($arrm->2) 30}
    :local totd  ((($yyyy - 1970) * 365) + (($yyyy - 1968) / 4) + ($arrm->$M) + ([:pick $vdate ($vdoff->4) ($vdoff->5)] - 1))
    :return      (((((($totd * 24) + [:pick $vtime 0 2]) * 60) + [:pick $vtime 3 5]) * 60) + [:pick $vtime 6 8] - $vgmt)
    :local NOW [$datetime2epoch]
    /tool user-manager session
    :foreach sessioneTest in=[find where active=yes] do={
        :local tilltime  [$datetime2epoch [get $sessioneTest till-time]]
        :local diff      ($NOW - $tilltime)
        :local threshold 120
        :if ($diff > $threshold) do={
            :log warning "Session closed: $[get $sessioneTest user] has been stalled for $diff seconds"
            close-session $sessioneTest
AAw
Thu Jan 19, 2023 12:16 am
Thank you very much, it worked very well.
I really appreciate your help.
rextended
Thu Jan 19, 2023 12:04 pm
Thanks also to you, for the reply!
kosarkarami726
Fri Aug 04, 2023 11:36 am
I have the problem too.
But my server and user manager are on two separate routers. What changes should I make in this scrpit and how should I run it?
rextended
Fri Aug 04, 2023 3:04 pm
The script work only where the user-manager is.
For run automatically the script, must be used the scheduler.
For be used manually, just paste it on terminal.
Is for RouterOS v6, not for RouterOS v7. On v7 user-manager not exist anymore, is just another shitty program called again user-manager.
kosarkarami726
Mon Aug 07, 2023 11:08 pm
thanks a lot.
yes you are right. shifty program!
we ran in to lots of problems with it.
I will run the script in a while and inform here.
Users browsing this forum: holvoetn and 17 guests
