Techsystem
Load Balancing doest work on my RB951ui
Sat Jan 14, 2023 4:05 pm
Hello My friends..!
so i am trying to setup load balancing on my RB951ui, i used this method from MUM lebanon 2019
https://mum.mikrotik.com/presentations/ ... 749570.pdf
but here is what i get -(see the counter parameters in the mangle and the NAT rule in picture below )-
so as you see all the traffic from WAN-2 not WAN-1, so where is the glitch in this config..??!
holvoetn
Re: Load Balancing doest work on my RB951ui
Sat Jan 14, 2023 4:57 pm
...so where is the glitch in this config..??!
What config ?
Unless you show it, nobody is going to be able to answer since a crystal ball, while handy, does not exist.
Terminal
Export
Remove sensitive info (serial number, WAN IP, ...)
Post between [ code] quotes.
anav
Sat Jan 14, 2023 6:02 pm
If you want PCC load balancing then this is the ref I use;;;;;;;;; https://mum.mikrotik.com/presentations/US12/steve.pdf
If its load balancing via bandwidth based its : https://mum.mikrotik.com/presentations/US12/tomas.pdf
Users browsing this forum: Bing [Bot], JmJ17, sch, unhuzpt and 110 guests
