Code: Select all
/system/reset-configuration keep-users=yes
In the past, keep-users would keep the old password.
Have you tried to create a new user, admin was not meant to be really used, the first thing you should do is to create a user for you and delete admin, if you do that, does it work as expected?On hAP ax3, Router OS 7.6:After this, the password is reset to the one printed on the pull-out tab. I find this very annoying. Is this behavior done on purpose?Code: Select all/system/reset-configuration keep-users=yes
