lox
Allow access to Hotspot network from managment VLAN
Mon Jan 16, 2023 10:27 am
I have a BASE VLAN that is allowed, by a firewall rule, to access all other VLANs.
I have a CUSTOMERS VLAN that have minimum access.
I can access the devices connected to the CUSTOMERS VLAN from the BASE VLAN. But as soon as I enable Hotspot on the CUSTOMERS VLAN, the Hotspot feature adds its own rules, and thus I cannot any more access the devices connected to the CUSTOMERS VLAN.
Which firewall rule would allow me to keep access to devices in the CUSTOMERS VLAN ?
Thanks.
/ip firewall filter print dynamic
Flags: X - disabled, I - invalid; D - dynamic
 0  D chain=forward action=jump jump-target=hs-unauth hotspot=from-client,!auth
 1  D chain=forward action=jump jump-target=hs-unauth-to hotspot=to-client,!auth
 2  D chain=input action=jump jump-target=hs-input hotspot=from-client
 3  D chain=input action=drop protocol=tcp hotspot=!from-client dst-port=64872-64875
 4  D chain=hs-input action=jump jump-target=pre-hs-input
 5  D chain=hs-input action=accept protocol=udp dst-port=64872
 6  D chain=hs-input action=accept protocol=tcp dst-port=64872-64875
 7  D chain=hs-input action=jump jump-target=hs-unauth hotspot=!auth
 8  D chain=hs-unauth action=reject reject-with=tcp-reset protocol=tcp
 9  D chain=hs-unauth action=reject reject-with=icmp-net-prohibited
10  D chain=hs-unauth-to action=reject reject-with=icmp-host-prohibited
11  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
/ip firewall nat print dynamic
 0  D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
 1  D chain=hotspot action=jump jump-target=pre-hotspot
 2  D chain=hotspot action=redirect to-ports=64872 protocol=udp dst-port=53
 3  D chain=hotspot action=redirect to-ports=64872 protocol=tcp dst-port=53
 4  D chain=hotspot action=redirect to-ports=64873 protocol=tcp hotspot=local-dst dst-port=80
 5  D chain=hotspot action=redirect to-ports=64875 protocol=tcp hotspot=local-dst dst-port=443
 6  D chain=hotspot action=jump jump-target=hs-unauth protocol=tcp hotspot=!auth
 7  D chain=hotspot action=jump jump-target=hs-auth protocol=tcp hotspot=auth
 8  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=80
 9  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=3128
10  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=8080
11  D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp dst-port=443
12  D chain=hs-unauth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
13  D chain=hs-auth action=redirect to-ports=64874 protocol=tcp hotspot=http
14  D chain=hs-auth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
Users browsing this forum: MauriceW and 102 guests
