bambinobub
Port Forwarding Broken?
Mon Jan 16, 2023 10:19 pm
Quick background:
Attempting to get OpenVPN running on network using a raspberry pi. I have the server configured, client configurations distributed, etc. UFW on the pi has both 443/tcp and 1194/udp open.
DST-NAT on the router appears to be broken. I cannot forward or open ANY ports in NAT and I'm 99% certain I have the rules appropriately configured.
I've pasted my firewall config below. Local VPN address is 192.168.88.94.
add action=passthrough chain=forward dst-port=44695 log=yes log-prefix=44695_forward protocol=tcp
add action=passthrough chain=input dst-port=44695 log=yes log-prefix=44695_input protocol=tcp
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=dst-nat chain=dstnat comment=OpenVPNServer_UDP/1194 dst-address=192.168.88.94 dst-port=1194 log=yes \
    log-prefix=OpenVPN_UDP protocol=udp to-addresses=192.168.88.94 to-ports=1194
add action=dst-nat chain=dstnat comment=OpenVPNServer_TCP/443 dst-address=192.168.88.94 dst-port=443 log=yes \
    log-prefix=OpenVPN_TCP protocol=tcp to-addresses=192.168.88.94 to-ports=443
To troubleshoot, I added a couple rules to the router firewall filter:
...and pushed them to the top of the list.
In telnet, I try to open a connection to my home IP via port 44695 and connection fails:
Connecting To 69.207.177.35...Could not open connection to the host, on port 44695: Connect failed
However, the INPUT chain rule above receives packets and data, while the FORWARD chain rule does not show any traffic.
Not sure what is causing packets to be blocked despite having NAT configured. Help is appreciated.
sindy
Re: Port Forwarding Broken?
Tue Jan 17, 2023 12:01 am
In both your dst-nat rules, dst-address (match condition) is the same like to-addresses (parameter of the dst-nat action), and dst-port is the same like to-ports, so the rules effectively do nothing.
Correct rules should say something like dst-address=wan.ip.of.the.router dst-port=44695 action=dst-nat to-addresses=192.168.88.94 to-ports=1194.
Since no dst-nat rule handles the incoming packets to port 44695 and the destination address of these packets is an own one of the router, these packets end in chain input.
filter follows nat, so once you fix the dst-nat rules, the passthrough rules in filter will not count either, because when reaching filter, the packets will already be dst-nated to port 1194.
bambinobub
Tue Jan 17, 2023 6:35 pm
Hey, sindy. Thanks for the reply. Apologies for taking a while to get back to you. I didn't receive an email when you replied and didn't realize my post was even approved yet.
I have a followup question.
I rewrote the DST-NAT rules and removed the filter rules as follows, with my public IP address where it says "my_public_ip" in the dst-nat rules. I assumed my wan ip for my router is my public IP. Please correct if I am wrong.
I'm still unable to get packets through that port. Any other diagnostics I could run for you?
add action=dst-nat chain=dstnat comment=OpenVPNServer_UDP/1194 dst-address="my_public_ip" dst-port=1194 log=yes \
add action=dst-nat chain=dstnat comment=OpenVPNServer_TCP/443 dst-address="my_public_ip" dst-port=443 log=yes \
bambinobub
Tue Jan 17, 2023 6:37 pm
1once again (pun intended) 99% arrogance fails to 1% truth.
Sorry, I don't understand what you're trying to say. I'm assuming it's an insult.
anav
Tue Jan 17, 2023 8:35 pm
No, just an observation, you are neither the first or last to think there is nothing wrong on the configuration, truth be told I am also equally guilty often providing configs that conrtain errors Its very difficult to get a complete config right the first time and thus why one of the keys to any MT config is make it as simple and clear as possible starting with firewall rules.....
sindy
Tue Jan 17, 2023 9:17 pm
It's not clear from what you have posted so far whether your Mikrotik has a public IP directly on its WAN or whether it is connected to the LAN of some other router provided by ISP.
In any case, the dst-nat rules you have posted now still match on dst-port=1194 and dst-port=443, whereas your telnet test shows that you've tried to connect to port 44695. So maybe that's the issue?
Another question is whether you do the tests from LAN of the same router or from outside (e.g. your mobile phone connected via the mobile network).
Users browsing this forum: jaclaz, tdw and 91 guests
