Grandes
2,4GHz SSID disappears after a few hours
Mon Jan 16, 2023 11:32 pm
Router: cap in bridge mode RBCAPGI-5ACD2ND
Installed Version v64.9.7
I have the configuration as described in post #5 viewtopic.php?t=177805
Auto reboot is set every 24 hours.
After few hours SSID for 2,4GHz disappears and all devices are disconnected. Tx and Rx is only 0.0 kbps. changing the settings doesn't help. Helps only manual reboot. After reboot everything works fine.
holvoetn
Re: 2,4GHz SSID disappears after a few hours
Tue Jan 17, 2023 8:27 am
Have you checked registration table ?
Are there devices which can ONLY connect to 2.4Ghz ? Because maybe they all moved to 5Ghz and then it's normal what you see.
A client will chose the most optimal connection on itself. And 5Ghz is usually better then 2.4Ghz, for the same SSID.
erlinden
Tue Jan 17, 2023 11:14 am
Is the SSID still broadcasted?
Does disable&enalbe the interface solve the problem?
Can you share your config?
/export file=anynameyoulike
Make sure you remove any personal information.
Grandes
Tue Jan 17, 2023 10:10 pm
there are 22 connected devices in 2,4GHz . These devices are only 2,4GHz. When there is a problem with the network, they are all disconnected. At the same time the network 5GHz is working fine.
Grandes
Tue Jan 17, 2023 10:25 pm
SSID is not broadcasted
disable&enalbe Wlan_2G doesn't help. Helps only System >> Reboot
# jan/17/2023 21:11:45 by RouterOS 6.49.7
# software id = N5VI-GBMC
# model = RBcAPGi-5acD2nD
# serial number = HCZ086JBxxx
add admin-mac=18:FD:74:7C:1C:xx auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk supplicant-identity=\
    MikroTik wpa-pre-shared-key=xxxxxxxxxx5 wpa2-pre-shared-key=xxxxxxxxxxx
add authentication-types=wpa2-psk mode=dynamic-keys name=securiti5g \
    supplicant-identity="" wpa2-pre-shared-key=xxxxxxxxxxxxx
add authentication-types=wpa2-psk mode=dynamic-keys name=securiti2g \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn comment=RBCAPGI-5ACD2ND \
    country=poland disabled=no distance=indoors mode=ap-bridge name=wlan_2G \
    security-profile=securiti2g ssid=kabel wireless-protocol=802.11 wps-mode=\
    disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=poland disabled=no distance=indoors frequency=\
    5200 installation=indoor mode=ap-bridge name=wlan_5G security-profile=\
    securiti5g ssid=Kabel5G wireless-protocol=802.11
/interface wireless manual-tx-power-table
set wlan_2G comment=RBCAPGI-5ACD2ND
/interface wireless nstreme
add name=dhcp ranges=192.168.88.10-192.168.88.254
add bridge=bridge comment=defconf interface=wlan_2G
add bridge=bridge comment=defconf interface=wlan_5G
add bridge=bridge interface=ether1
set discover-interface-list=all
add interface=ether2 list=LAN
add interface=wlan_5G list=LAN
add interface=wlan_2G list=LAN
/ip dhcp-client
add comment=defconf disabled=no interface=bridge
set allow-remote-requests=yes
/ip dns static
    established,related,untracked disabled=yes
    invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=RouterOS
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system scheduler
add interval=1d name="Auto reboot" on-event="system reboot" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=jan/02/2023 start-time=03:00:51
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
bpwl
Tue Jan 17, 2023 10:40 pm
Anything in the log file, around the time of SSID disappearence? You might add "/system logging add topics=wireless" to see something more.
What reason is given for the disconnects in the LOG ?
The Log will be cleared with the daily reboot. Daily reboots are common on my other brand APs, never on Mikrotik, those run for years non-stop.
Grandes
Wed Feb 01, 2023 6:01 pm
Tue Jan 17 I moved google nest mni and chromecast devices to 5GHz network and until today everything worked fine.
Today at 13:27 the network crashed :(
bpwl
Wed Feb 01, 2023 7:41 pm
2GHz network: group key exchange timeout.
Looks like clients didn't get the WPA/WPA2 key-change information. They will stop ALL being able to encrypt/decrypt properly.
https://www.techwalla.com/articles/what ... y-interval
"group key exchange timeout" is in many posts in this forum, and is all over the internet for other brands.
I did not find a proper workaround or fix.
If group key updates are sent via broadcast/multicast there is quite a possibility this is missed by some or all clients.
Broadcast/multicast uses the low basic-rate interface rate, to be sure to reach all clients without fault.
However with broadcast/multicast there is NO feedback, so there are NO retries like with unicast.
Unicast can survive glitches in the wifi-ether, because it resends as needed. Broadcast/multicast will fail if disturbed !
Some AP operators rise the lowest basic rate higher than 6Mbps, to save some air-time for beacons. However higher basic-rates will fail more often.
Setting the "Group Key Update" interval in the security profile higher than the default 5 minutes, will reduce the problem.
1 hour and longer is not uncommon ! see: https://community.cisco.com/t5/wireless ... -p/4135411
I don't know if setting the Multicast helper to "full" on the wifi interface , will also convert this to unicasts!?
(Helper default setting is "default" , currently the same as "disabled")
Users browsing this forum: oskarsk and 55 guests
