gabeselig1
Anyone else missing POE on v7.7?
Tue Jan 17, 2023 4:55 am
Upgraded part of our network from v7.6 to 7.7. We run several CRS328-24P-4S+. Noticed that export no longer includes poe-out information. Tab is also missing from winbox; however, one can still set poe-out through terminal. Nothing mentioned in changelog about POE.
Anyone other models missing POE besides the CRS328 ? On one switch, only missing on ports 17-24. Present on ports 1-16. On a separate switch, shows up on ports 1-8 but missing from ports 9-24.
Separate switch, all ports are fine. POE Controller initialization issue?
Guscht
Re: Anyone else missing POE on v7.7?
Tue Jan 17, 2023 7:23 pm
PoE is there
gabeselig1
Re: Anyone else missing POE on v7.7?  [SOLVED]
Tue Jan 17, 2023 8:33 pm
Software reboot does not resolve. Hard reboot of the switch returns the missing POE section but lost previously configured POE setup.
AndreyRa
Sat Dec 09, 2023 1:56 am
I've got same behavoir when I was updated my switches from 6.49.8 to 7.11.2.
Fortunately it was solved in 7.12 firmware:
*) poe-out - fixed rare CRS328 poe-out menu and poe-out port config loss after reboot;
And I confirm that 7.12.1 successfully restores all PoE tabs for 9-24 ports of CRS328-24P-4S+ switches.
Users browsing this forum: nclmrc and 20 guests
