sunakashi
PoE+ on HAP ac3?
Tue Jan 17, 2023 8:28 pm
I bought PoE+ switch TL-SG1005P because I want get rid of adapter on my HAP ac3 router. I was surprised that it does not work. Then I googled this: viewtopic.php?t=120809 and find out that there is difference between PoE+ and 802.3af (passive)
So... Before I return switch I just ask simple question. Is HAP ac3 really not compatible with PoE+? Specs on switch writes that it is 802.3 af/at compliant. Maybe I need turn on something in RouterOS? Thanks.
mkx
Re: PoE+ on HAP ac3?
Tue Jan 17, 2023 10:26 pm
hAP ac3 product page specifies it's PoE in is passive (not 802.3 af/at). Another hint is input voltage range (12-28V) which doesn't allow 802.3 af/at voltags - range there is centered around 48V.
sunakashi
Tue Jan 17, 2023 11:02 pm
Specs of switch does not say anything about passivity or activity of PoE. I'm confused. Which switch should I look for then?
mkx
Tue Jan 17, 2023 11:19 pm
Specs of switch says it's 802.3 af/at compliant ... which by its definition is not passive. It also mentions a 53.5V power adapter, which is completely sensible for a 802.3 af/at PSE.
sunakashi
Wed Jan 18, 2023 11:34 am
So which device should I look for in similar price range that is compatible with HAP ac3 PoE in? It does not have to be a switch. I can use separate switch without PoE, I just need powering router from PoE and get rid of adapter.
rolling
Wed Jan 18, 2023 11:45 am
@sunakashi sorry for use your post...
I've same doubts, is posible power a hAP AC3 or other Pasive POE in device with a CSS610-8P-2S+IN or a RB5009UPr+S+IN?
Regards.
sunakashi
Wed Jan 18, 2023 11:47 am
Will this injector work with adapter from HAP ac3? https://mikrotik.com/product/RBGPOE I cannot find size of DC input.
mkx
Wed Jan 18, 2023 10:39 pm
Yes, all round plugs on Mikrotik devices are same dimensiobs and RBGPOE fits as well.
The problem with passive PoE is that all implementations are proprietary. There are only so many combinatiins of those 8 wires in UTP cable so not all implementations are different. The best chance is to go for same vendor (e.g. use Mikrotik switch).
And then there's the issue with compatible voltages. Meaning not every MT switch necessarily fits the bill. You have to verify if chosen PoE switch is compatible with your hAP ac3.
Reyestatrin
Thu Jan 19, 2023 11:32 am
That was the first thing I stared. Not so much, just:PoE out Passive PoEMax out per port output (input 18-30 V) 0.5 AMax total out (A) 0.5 A Based on that can I be sure that AP will run?
sunakashi
Thu Jan 19, 2023 1:08 pm
I can confirm that RBGPOE works with adapter from HAP ac3. Now I can finally put my router on place without power socket near by!
Users browsing this forum: No registered users and 83 guests
