charleselie
rate limit in the server profile tab of the hotspot
Wed Jan 18, 2023 4:42 pm
what is the use of rate limit in the server profile tab of the hotspot ?
erlinden
Re: rate limit in the server profile tab of the hotspot
Wed Jan 18, 2023 4:50 pm
Where exactely do you see this setting?
I checked the helppage, but it wasn't mentioned:
https://help.mikrotik.com/docs/pages/vi ... d=56459266
If it has to do with the wireless device:
https://help.mikrotik.com/docs/display/ ... SRatetable
charleselie
Wed Jan 18, 2023 4:57 pm
I add limits but I don't see any change
Please explain to me the usage?
[/quote]
erlinden
Wed Jan 18, 2023 5:34 pm
Seems that the help page is not up to date yet, the wiki is:
https://wiki.mikrotik.com/wiki/Manual:I ... ot/Profile
Rate limitation in form of rx-rate[/tx-rate] [rx-burst-rate[/tx-burst-rate] [rx-burst-threshold[/tx-burst-threshold] [rx-burst-time[/tx-burst-time]]]] [priority] [rx-rate-min[/tx-rate-min]] from the point of view of the router (so "rx" is client upload, and "tx" is client download). All rates should be numbers with optional 'k' (1,000s) or 'M' (1,000,000s). If tx-rate is not specified, rx-rate is as tx-rate too. Same goes for tx-burst-rate and tx-burst-threshold and tx-burst-time. If both rx-burst-threshold and tx-burst-threshold are not specified (but burst-rate is specified), rx-rate and tx-rate is used as burst thresholds. If both rx-burst-time and tx-burst-time are not specified, 1s is used as default. rx-rate-min and tx-rate min are the values of limit-at properties
What version RouterOS are you running?
charleselie
Wed Jan 18, 2023 6:22 pm
The version RouterOS are 6.49
Users browsing this forum: Bing [Bot] and 80 guests
