shafique
Qualcomm QCA6174
Thu Jan 19, 2023 1:46 am
Is Qualcomm QCA6174 supported by Mikrotik, I cannot see it in wireless section.
BartoszP
Re: Qualcomm QCA6174
Thu Jan 19, 2023 9:38 am
So the conclusion is: not offcialy. That it is the compatibility matrix for :)
shaf6192
Thu Jan 19, 2023 11:19 am
how to enable it, please help.
shaf6192
Thu Jan 19, 2023 11:20 am
how to enable it, please help. I am using X86 image.
BartoszP
Thu Jan 19, 2023 11:23 am
Why do you quote whole preceding posts? Even your ones.
Is it a problem to just use "Post Reply" button? Is It a problem to just answer?
Do you repeat the question of your interlocutor if you discuss?
shaf6192
Thu Jan 19, 2023 11:28 am
Its showing up in /system/resources but cant see any wlan interface in wireless
shaf6192
Thu Jan 19, 2023 11:32 am
oh sorry, new here, just found the 'post reply' button :) sorry again
mkx
Thu Jan 19, 2023 3:02 pm
There are two things in linux (and thus in ROS) when it comes to hardware: 1) enumeration of pheripherial devices - names are derived from a well known pciIDS database (or similar usb-ids for USB devices) and 2) driver support, which has to be included with linux distribution/kernel or ROS. While linux kernels and most distributions include most if not all drivers available, ROS only includes drivers for hardware officially supported by Mikrotik. Things get added even to x86 variant, but you may have to ask support@mikrotik.com if that's gonna happen.
So in short: things are same as with medical doctors: if the guy knows the name for disease, it doesn't mean he knows how to treat it.
shafique
Fri Jan 20, 2023 12:00 am
thanks @mks for a detailed reply. Really disappointing to know Mikrotik not having support for even common wireless interfaces.
shafique
Fri Jan 20, 2023 12:02 am
does Mikrotik have any list of wireless devices being supported in x86?
mkx
Fri Jan 20, 2023 8:48 am
A bit older thread about similar topic: viewtopic.php?t=154119
shaf6192
Fri Jan 20, 2023 11:48 am
Thank you @mkx, its been really helpful, cheers
DyadyaGenya
Fri May 12, 2023 11:47 pm
Did you manage to connect this module to your Mikrotik?
Users browsing this forum: bpwl, Majestic-12 [Bot], Nullcaller, Scoox and 25 guests
