dragon2611
RB4011 crashing with 7.7
Thu Jan 19, 2023 3:02 pm
Seems my RB4011 is crashing/rebooting since being upgraded from 7.6 to 7.7
Nothing much in the logs over than "cloud change time", sent a supout to support to see if they can see why's it's doing it.
Anyone else been having issues with 7.7?
holvoetn
Re: RB4011 crashing with 7.7
Thu Jan 19, 2023 3:05 pm
How did you move from ROS6 to ROS7 on that device ?
Upgrade to upgrade to upgrade ... ?
It might be time to netinstall.
erlinden
Thu Jan 19, 2023 3:06 pm
Nope...
How fast after boot does it happen?
Have you sent the supout file yet?
Anything exotic in your config?
dragon2611
Thu Jan 19, 2023 3:09 pm
What are you quotiing whole preceding post for? Does it help answering? Use "Post Reply" button.
Seems random, yes I sent a supout.
Config has a L2TP tunnel and a second routing table to use it/ some routing rules but otherwise no not particularly exotic.
Reason: removed excessive quotting of preceding post; be wise, quote smart, save network traffic
erlinden
Thu Jan 19, 2023 3:32 pm
Take in consideration what @holvoetn mentioned: export your complete config (/export show-sensitive file=anynameyoulike), do a netinstall and perform an import of the config (/import file=anynameyoulike). Hope it helps!
DanMos79
Thu Jan 19, 2023 3:39 pm
I noticed a memory leak in the DNS server in version 7.7 on my RB4011. Has already been reported to support, have not received an answer so far.
Maybe this is the cause of some crashes.
Herfik
Wed Feb 15, 2023 1:44 pm
I noticed that on all mikrotik devices including CRS (where CPU doesn't really do anything besides SNMP regularly). Also virtual machines on x86 have the same issue.
dragon2611
Fri Feb 17, 2023 12:46 pm
Forgot to update this thread:
Had a support ticket open about it and they kept wanting me to try a different power source, even after I'd discovered that removing a un-needed bridge configuration stabilised it and told them this.
I had eth1 and eth2 in a bridge but as nothing was connected to eth2 anymore it was un-needed legacy configuration, since removing the bridge it's been stable
4wifi
Tue Mar 07, 2023 3:42 am
I have a memory leak also on multiple routers that run as Hotspot controllers. I have simplified the bridging down to the lowest point where it will still function and will see how it goes.
4wifi
Sat Mar 11, 2023 2:00 pm
I went to 7.8 and the memory leaks seem to have stablised considerably. Not entirely convinced they are gone, but it is clear they are significantly improved.
Also noticed same on a hAP ac lite unit for which the upgrade to 7.8 completely fixed it.
4wifi
Mon Mar 13, 2023 12:51 am
7.8 has indeed resolved the issue. Although nothing in the changelogs to indicate this should be the case or if something was actually identified that I can find.
Users browsing this forum: Ahrefs [Bot], anav, araqiel, Google [Bot], pe1chl, simonefil and 83 guests
