Guscht
VLAN-Filtering enabled + use-tag -> no connection
Thu Jan 19, 2023 8:35 pm
I tried with ROS 7.7 to create multiple SSIDs, separated with VLANs as decribed here:
https://wiki.mikrotik.com/wiki/Manual:VLANs_on_Wireless
Here is stated:
Note: It is important to set wlan1,wlan2 vlan-mode to "use-tag".
And:
add fast-forward=no name=bridge1 vlan-filtering=yes
But exactly THIS does NOT work!
vlan-filtering=yes + use-tag -> no connection
vlan-filtering=no + use-tag -> connection
vlan-filtering=yes + no-tag -> connection
If you choose "vlan-filtering=yes + no-tag" it is needed to set the correct PVID on the VLAN-Ports too!
Can someone explain this and why it is described that way in the wiki?
pe1chl
Re: VLAN-Filtering enabled + use-tag -> no connection
Thu Jan 19, 2023 8:39 pm
There are two ways, you need to decide which one you use:
1. you have your wlan interfaces connected to a tagged bridge port, or a tagged ethernet interface.
then you set the wlan interface to "use tag" and put the proper VLAN number in the tag.
2. you use the (newer) vlan-filtering bridge with the wlan interface connected as an untagged port on the correct VLAN.
then you do NOT set the wlan interface to "use tag".
anav
Thu Jan 19, 2023 11:44 pm
Users browsing this forum: No registered users and 26 guests
