redboy
Vlan passthough on WiFi link
Thu Jan 19, 2023 9:04 pm
Hello
I have a problem with Vlans not going through a WiFi link.
The link is between an Omnitik 5HacD and a Sextant.
The eth ports of each SW are configured as trunk for all the VLANs and the communication between them within the SW works.
But through the link only Vlan 1 (default, untagged) passes
The link is in transparent bridge mode. No firewall or rule has been set in it.
The routerboad version on all them is 6.49.6
Any ideas?
anav
Re: Vlan passthough on WiFi link
Thu Jan 19, 2023 11:44 pm
nichky
Fri Jan 20, 2023 7:12 am
what @anav is saying is the right way to go.
To make it simple, export the config , to see what exactly u are doing.
Users browsing this forum: No registered users and 36 guests
