vchrizz
SFP modules on CRS devices
Fri Jan 20, 2023 12:27 am
having already read other posts about SFP modules on CRS like the following I just wanted to share another experiences on CRS326-24G-2S+ (currently RouterOS v7.7) with copper SFP RJ45 modules, maybe someone finds it interesting.
Ordered the S+RJ10 module from Mikrotik and hope that this will work, will report experiences here.
The following modules mentioned here work fine with other devices but sadly none of them seem to work on the CRS.
Even when auto-negotiation disabled and you manually set a specific speed they still do not work.
HP 1Gb SFP RJ-45 Module - Spares PN: 453156-001 - Type: copper - Speed: 1000M
 > /interface/ethernet/monitor sfp-sfpplus2
                             status: no-link
                   auto-negotiation: failed
                        advertising:
           link-partner-advertising:
                 sfp-module-present: yes
                        sfp-rx-loss: no
                       sfp-tx-fault: no
                           sfp-type: SFP-or-SFP+
  sfp-link-length-copper-active-om4: 100m
                    sfp-vendor-name: FINISAR CORP.
             sfp-vendor-part-number: FCLF-8521-3-HP
                sfp-vendor-revision: A
                  sfp-vendor-serial: PJR4XV8
             sfp-manufacturing-date: 10121851
                    eeprom-checksum: good
                             eeprom: 0000: 03 04 00 00 00 00 08 00  00 00 00 01 0c 00 00 00  ........ ........
                                     0010: 00 00 64 00 46 49 4e 49  53 41 52 20 43 4f 52 50  ..d.FINI SAR CORP
                                     0020: 2e 20 20 20 00 00 90 65  46 43 4c 46 2d 38 35 32  .   ...e FCLF-852
                                     0030: 31 2d 33 2d 48 50 20 20  41 20 20 20 00 00 00 81  1-3-HP   A   ....
                                     0040: 00 10 00 00 50 4a 52 34  58 56 38 20 20 20 20 20  ....PJR4 XV8
                                     0050: 20 20 20 20 31 30 31 32  31 38 35 31 00 00 00 c9      1012 1851....
                                     0060: 00 00 00 d0 00 81 45 01  34 35 33 31 35 36 2d 30  ......E. 453156-0
                                     0070: 30 31 20 20 20 20 00 00  1d af e9 86 17 9f 6f f6  01    .. ......o.
                                     0080: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
Foundry E1MG-TX - Type: copper - Speed: 1000M
                             status: no-link
                        advertising:
                        sfp-rx-loss: yes
                       sfp-tx-fault: no
                    sfp-vendor-name: FOUNDRY NETWORKS
             sfp-vendor-part-number: DM7041-FN-C
                sfp-vendor-revision: C
                  sfp-vendor-serial:         00015553
             sfp-manufacturing-date: 07040201
                     sfp-wavelength: 16653.93nm
           sfp-dwdm-channel-spacing: 1Ghz
                             eeprom: 0000: 03 04 00 00 00 00 08 00  00 00 00 01 0d 00 00 00  ........ ........
                                     0010: 00 00 64 00 46 4f 55 4e  44 52 59 20 4e 45 54 57  ..d.FOUN DRY NETW
                                     0020: 4f 52 4b 53 01 00 00 00  44 4d 37 30 34 31 2d 46  ORKS.... DM7041-F
                                     0030: 4e 2d 43 20 20 20 20 20  43 20 20 20 41 0c c1 25  N-C      C   A..%
                                     0040: 00 00 00 00 20 20 20 20  20 20 20 20 30 30 30 31  ....         0001
                                     0050: 35 35 35 33 30 37 30 34  30 32 30 31 00 00 00 21  55530704 0201...!
                                     0060: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  ........ ........
Ubiquiti UF-RJ45-1G - Type: copper - Speed: 10/100/1000M
                             status: no-link
                        advertising:
                        sfp-rx-loss: yes
                       sfp-tx-fault: no
                    sfp-vendor-name: UBNT
             sfp-vendor-part-number: UF-RJ45-1G
                sfp-vendor-revision: 1.0
                  sfp-vendor-serial: X20092800327
             sfp-manufacturing-date: 20-08-18
                                     0010: 00 00 64 00 55 42 4e 54  20 20 20 20 20 20 20 20  ..d.UBNT
                                     0020: 20 20 20 20 00 00 00 00  55 46 2d 52 4a 34 35 2d      .... UF-RJ45-
                                     0030: 31 47 20 20 20 20 20 20  31 2e 30 20 00 00 00 1b  1G       1.0 ....
                                     0040: 00 00 00 00 58 32 30 30  39 32 38 30 30 33 32 37  ....X200 92800327
                                     0050: 20 20 20 20 32 30 30 38  31 38 20 20 00 00 00 7c      2008 18  ...|
                                     0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
Kind regards!
vchrizz
Re: SFP modules on CRS devices
Mon Jan 23, 2023 5:37 pm
apparently the mikrotik module works:
Mikrotik S+RJ10 - Type: copper - Speed: 10/100/1000/2500/5000/10000M
                             status: link-ok
                   auto-negotiation: done
                               rate: 1Gbps
                        full-duplex: yes
                    tx-flow-control: no
                    rx-flow-control: no
                        advertising: 10M-half,10M-full,100M-half,100M-full,
                                     1000M-half,1000M-full,10000M-full,
                                     2500M-full,5000M-full
           link-partner-advertising: 10M-half,10M-full,100M-half,100M-full,
                                     1000M-full
                        sfp-rx-loss: no
                       sfp-tx-fault: no
                 sfp-connector-type: RJ45
  sfp-link-length-copper-active-om4: 1m
                             status: link-ok
                               rate: 1Gbps
                        full-duplex: yes
                    tx-flow-control: no
                    rx-flow-control: no
                        advertising: 10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full,2500M-full,
                                     5000M-full
           link-partner-advertising: 10M-half,10M-full,100M-half,100M-full,1000M-full
                        sfp-rx-loss: no
                       sfp-tx-fault: no
                    sfp-vendor-name: MikroTik
             sfp-vendor-part-number: S+RJ10
                sfp-vendor-revision: 2.16
                  sfp-vendor-serial: F060033227BD
             sfp-manufacturing-date: 22-06-13
                    sfp-temperature: 79C
                 sfp-supply-voltage: 3.312V
                sfp-tx-bias-current: 0mA
                             eeprom: 0000: 03 04 22 00 00 00 00 00  08 00 00 06 67 00 00 00  .."..... ....g...
                                     0010: 00 00 01 00 4d 69 6b 72  6f 54 69 6b 20 20 20 20  ....Mikr oTik
                                     0020: 20 20 20 20 00 00 40 20  53 2b 52 4a 31 30 20 20      ..@  S+RJ10
                                     0030: 20 20 20 20 20 20 20 20  32 2e 31 36 05 00 00 b0           2.16....
                                     0040: 02 1a 00 00 46 30 36 30  30 33 33 32 32 37 42 44  ....F060 033227BD
                                     0050: 20 20 20 20 32 32 30 36  31 33 20 20 68 00 06 0b      2206 13  h...
                                     0080: 78 00 d8 00 64 00 00 00  8c a0 55 f0 88 b8 75 30  x...d... ..U...u0
                                     0090: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                                     00d0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 0a  ........ ........
                                     00e0: 4f 00 81 60 00 00 00 00  00 00 00 00 00 00 00 00  O..`.... ........
                                     00f0: 00 00 00 00 00 00 02 00  ac 00 d1 e1 00 00 7b 00  ........ ......{.
Users browsing this forum: Amazon [Bot], hatred, lurker888 and 74 guests
