qatar2022
Docker Pihole container on USB
Fri Jan 20, 2023 9:32 am
Dear all
I install pihole container on my MK RB5009 ( finally) and I think it’s working and as you know while pihole works on MK it’s takes up space from MK memory
When I tried to install pihole on usb and during extracting I get error!!!!
Do you know what is wrong I made? I already format usb ext3 and ext4 but with no succeed
Now can I transfer all pihole data from internal storage to usb?
Thank you and best regatds
Znevna
Re: Docker Pihole container on USB
Fri Jan 20, 2023 9:36 am
read the manual
gabacho4
Fri Jan 20, 2023 9:54 am
Need to see output of system/disks/print.
Also need to see your container settings in their entirety. Don't have access to my 5009 but believe /container/print might work.
qatar2022
Fri Jan 20, 2023 11:45 am
[admin@MikroTik RB5009UG+S+] > container/print
0 name="ffb12c5a-7b19-4438-b064-8002de34b7ae" tag="pihole/pihole:latest"
os="linux" arch="arm64" interface=veth1 envlist="pihole_envs"
root-dir=disk1/pihole mounts=etc_pihole,dnsmasq_pihole dns=""
start-on-boot=yes status=running
gabacho4
Fri Jan 20, 2023 1:09 pm
You forgot to provide the output of system/disks/print.
Currently your container is set to use the router's nand memory. Not USB.
qatar2022
Fri Jan 20, 2023 3:44 pm
dear gabacho4
thank you for your reply and help
I didn't use usb yet I'm using now routers Nand memory because i got an error during extracting image
bibos
Sun Jan 22, 2023 1:21 pm
I have the same problem, it seems that is a bug
It should be like that:
and disks:
I've made it work only after these steps:
- create a container with rootDir on disk1/pull
- Run container
- After downloading and extracting, remove container
- Flash disk with partition
- Create a container with normal rootDir as manual says "disk1/pihole"
Users browsing this forum: No registered users and 2 guests
