Caporeira
Netflix over Tailscale (ExitNode)
Fri Jan 20, 2023 11:06 pm
it is possibile config Mikrotik Ax3 v7.7 to put only Netflix traffic over Tailscale ?
How to do that ?
Tailscale wan't to start on Container :(
How to fix it ?
Caporeira
Re: Netflix over Tailscale (ExitNode)
Wed May 24, 2023 9:45 pm
Any neu possibility to run tailscale on mikrotik router?
optio
Long time Member
Long time Member
Wed May 24, 2023 10:19 pm
Maybe is related to this similar issue: https://github.com/containers/podman/issues/17016
Try to set PATH env. variable for this container with value: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Larsa
Wed May 24, 2023 11:00 pm
Unfortunately not on native RoS, but you might try ZeroTier that is similar to TailScale.
antonsb
Thu May 25, 2023 11:52 am
path issues should be fixed in latest beta versions
Users browsing this forum: No registered users and 3 guests
