sergiobeltrao
Auto upgrade not working on ROSv7.7?
Sat Jan 21, 2023 4:56 am
Ok, I have never tried the "Auto Upgrade" tool and decided to test it now, but it seems to me that it is not working. I have putted the RouterOS file in one VirtualRB to upgrade my real hAP ac² then went to "System > Auto Upgrade > Upgrade Package Sources" and added the IP of the RB where the files are with user and password but when I go to "Available Packages" and do the refresh nothing appears.
What I have noticed...
- After doing this if I try to access the command line "/system/upgrade/upgrade-package-source/print" the terminal does not print anything and I ended up receiving the message "action timed out - try again, if error continues contact MikroTik support and send a supout file (13)" after some time
- If I try to upload any file (on the Mikrotik), it does not upload anything.
- I can't remove the previous configuration in "Upgrade Package Sources" or add a new one.
- One of the CPU cores went to 100% when is usually less than 5% with my config.
- After I reboot the router the configuration disappears and if I try to configure it again I get the same behavior.
Users browsing this forum: Amazon [Bot], vagrik and 190 guests
