lkspodmol
SMB on hAP lite TC?
Sat Jan 21, 2023 11:59 pm
Hey so i wantd SMB on my hAP lite TC but i didnt se usb port. Is there a way to plug usb to ethernet adapter and it whould work? Im noobie.
antonsb
Re: SMB on hAP lite TC?
Mon Jan 23, 2023 11:11 am
no, only power is connected to USB port for this model.
hecatae
Mon Jan 23, 2023 12:48 pm
You can swap the power supply for a PWR-LINE: https://mikrotik.com/products/group/dat ... powerlines
You would then need a compatible MikroTik at the other end to attach your SMB to, MAP for example has a USB port for SMB.
holvoetn
Mon Jan 23, 2023 12:58 pm
But the question I pose when reading this: performance ?
hecatae
Mon Jan 23, 2023 1:54 pm
10/100 Ethernet ports so it's going to be slow, but technically PWR-LINE is USB to Ethernet, just really expensive as you require 2 of them and another Tik at the other end.
The OP may be better off with a mAP-2nd and a switch or a hAP ac Lite
Users browsing this forum: No registered users and 31 guests
