voytec
script running problem
Sun Jan 22, 2023 11:37 pm
I have a problem when running a script from terminal and via scheduler or "Run Script" button.
:local rchbl
:if ([/ping 8.8.8.8 count=2] < 0 || [/ping 8.8.4.4 count=2] < 0 ) do={:set rchbl 1} else={:set rchbl 0}
:log info $rchbl
:put $rchbl
When i use terminal
/system/script run script1
the script returns 1
but...
if I use scheduler or "Run script" button
the script returns 0
What am I doing wrong??
rextended
Re: script running problem
Mon Jan 23, 2023 12:44 am
You do not specify RouterOS version.
On v6
< 0 ???
You give less than 0 successfully results?
And i never get 1 on terminal
Users browsing this forum: diamuxin and 24 guests
