rmenkveld
Memory leak after L2TP enble with RoS7.6
Mon Jan 23, 2023 10:47 am
Has anyone noticed a memory leak when using RouterOS 7.6 with an RB3011.
We have been using this router for a week, for the first day and a half we routed the traffic to the outside via a masquerade rule. Since Tuesday, we have been routing all traffic to our data center via an L2TP tunnel. I can clearly see in the logging that there has been a memory leak since then.
The router gives the following message:
router was rebooted without proper shutdown, probably kernel failure
kernel failure in previous boot
out of memory condition was detected
How can I tell which process is consuming so much memory?
MrYan
Re: Memory leak after L2TP enble with RoS7.6
Mon Jan 23, 2023 9:32 pm
See a similar thing (although not with the same severity) on 7.7 on a hAP ax2 using an L2TP tunnel for Internet access:
It's low bandwidth/throughput which might explain the slow leak.
Users browsing this forum: sinateifouri and 200 guests
