dksoft
Alpine fails because of NXDOMAIN with missing IPv6 entry in ROS DNS
Mon Jan 23, 2023 12:35 pm
My problem is with Alpine Linux v3.16 because the RouterOS 7.7 DNS server returns NXDOMAIN if an IPv6 entry does not exist, even that an IPv4 does exist.
I tried other DNS, like DNSMASQ/Pi-hole in a Docker container and they return NOERROR instead.
Unfortunately Alpine always asks for A and AAAA record and if one return NXDOMAIN, it fails. Even if a IPv4 record does exist.
Any idea how to change the RouterOS response to not return NXDOMAIN?
Here is my configuration:
set allow-remote-requests=yes
/ip dns static
add address=10.0.0.17 name=ess
Alpine fails to ping:
mosquitto:~# ping ess
ping: bad address 'ess'
Here is the reason:
mosquitto:~# nslookup ess
Server:		10.0.0.1
Address:	10.0.0.1:53
Non-authoritative answer:
Address: 10.0.0.17
** server can't find ess: NXDOMAIN
Debug IPv4:
mosquitto:~# nslookup -type=a -debug ess 10.0.0.1
Server:		10.0.0.1
Query #0 completed in 1ms:
Address: 10.0.0.17
Debug IPv6:
mosquitto:~# nslookup -type=aaaa -debug ess 10.0.0.1
Server:		10.0.0.1
Query #0 completed in 3ms:
This is how DNSMASQ/Pi-hole @10.0.0.6 responses in the same configuration:
mosquitto:~# nslookup -type=aaaa -debug ess 10.0.0.6
Server:		10.0.0.6
Address:	10.0.0.6:53
Query #0 completed in 0ms:
chyparo
Re: Alpine fails because of NXDOMAIN with missing IPv6 entry in ROS DNS
Thu Feb 02, 2023 10:54 pm
I have exactly the same problem. ROS 7.7
dksoft
Fri Feb 03, 2023 4:43 pm
Fixed in 7.8b3
nickvacula
Thu Mar 30, 2023 4:12 pm
unfortunately for me on RouterOS v7.8 stable it still returns NXDOMAIN instead of NOERROR from Alpine:
# nslookup <my.home.host>
Server: 192.168.88.1
Address: 192.168.88.1:53
** server can't find <my.home.host>: NXDOMAIN
# nslookup -type=a <my.home.host>
# nslookup -type=aaaa <my.home.host>
# cat /etc/resolv.conf
# Generated by NetworkManager
search <home.host>
nameserver 192.168.88.1
wat this fix missed in 7.8 stable?
EDIT: just found it works fine if I don't have "Use DoH Server" field set. If I have DoH server configured - query from Alpine still returns NXDOMAIN.
nickvacula
Thu Apr 06, 2023 2:09 pm
@dksoft can you please check if problem still exists for you if you have "Use DoH Server" checked?
Amm0
Fri Apr 07, 2023 12:59 am
Correct, container does not work with DoH set, see:
viewtopic.php?t=194302&hilit=alpine#p989096
There was a separate bug in the ~7.6 where IPv6 resolution was broken – that may also been the original issue in this thread. Which is different from Alpine with DoH.
Alpine's native DNS resolver only uses UDP and even ignores fragmented responses if I recall right... but there is not "native" DoH support in Alpine.
Users browsing this forum: aferreira, Google [Bot], kanecharles and 199 guests
