karaYusuf
Changing an IP-Address
Mon Jan 23, 2023 3:13 pm
Hello Guys.
I wanted to write a script, which changes some ip-address values. I wanted to delete every char after the "/" in an ip-address.
As expample turning 192.168.1.100/24 to 192.168.1.100
I wrote the following code but can not get any output.
        :local Pstring 192.168.1.100/24
        :local cP;
        :local slash /;
            :for i from=0 to=([:len $Pstring] - 1) do={
                :local char [:pick $Pstring $i];
                :local oneAfter [:pick $Pstring [$i +1]];
                :local twoAfter [:pick $Pstring [$i +2]];
                :if ($char = $slash) do={
                    :set $char  "";
                    :set $oneAfter "";
                    :set $twoAfter "";
                :set $cP ($cP . $char)
            :put $cp;
What am I doing wrong?
Any help would be appreciated:)
diamuxin
Re: Changing an IP-Address
Mon Jan 23, 2023 4:43 pm
Something like that?
:local ipAdd 192.168.1.100/24
:set ipAdd [:toip [:pick $ipAdd 0 [:find $ipAdd "/"]]]
:put $ipAdd
Output ==> 192.168.1.100
BR.
rextended
Mon Jan 23, 2023 4:54 pm
@karaYusuf You do it on wrong way, and the topic title is completely inadequate.
:local lcidr 192.168.1.100/24
:local lip   [:pick $lcidr 0 [:find $lcidr "/"]]
:local lsub  [:pick $lcidr ([:find $lcidr "/"] + 1) [:len $lcidr]]
:put "$lcidr = $lip / $lsub"
karaYusuf
:put $ipAdd
BR.
Exactly what I needed. Thank you very much :)
karaYusuf
Mon Jan 23, 2023 4:57 pm
I am sorry.
So which one should I use?
The one you wrote me or the other one?
rextended
Mon Jan 23, 2023 5:01 pm
Both do the same, the second (my) do not uselessly use :toip‡ and containing also one example for extract subnet, if is needed,
and also the variable names are more adequate....
‡: depend on the rest of the script...
Users browsing this forum: caminskibr and 36 guests
