pabelo76
hAP AX3 poor wifi transfers
Mon Jan 23, 2023 9:23 pm
Hello everyone,
I need hints on how to configure wifi to get satisfactory transfers.
Here are my iperf3 results on the local network:
Connecting to host 192.168.3.33, port 5201
[  4] local 192.168.4.253 port 63445 connected to 192.168.3.33 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  45.0 MBytes   377 Mbits/sec
[  4]   1.00-2.00   sec  51.4 MBytes   431 Mbits/sec
[  4]   2.00-3.01   sec  51.0 MBytes   425 Mbits/sec
[  4]   3.01-4.00   sec  48.0 MBytes   405 Mbits/sec
[  4]   4.00-5.00   sec  48.2 MBytes   405 Mbits/sec
[  4]   5.00-6.00   sec  45.0 MBytes   378 Mbits/sec
[  4]   6.00-7.00   sec  48.2 MBytes   405 Mbits/sec
[  4]   7.00-8.00   sec  49.4 MBytes   414 Mbits/sec
[  4]   8.00-9.00   sec  46.8 MBytes   392 Mbits/sec
[  4]   9.00-10.00  sec  48.0 MBytes   403 Mbits/sec
[  4]   0.00-10.00  sec   481 MBytes   403 Mbits/sec                  sender
[  4]   0.00-10.00  sec   481 MBytes   403 Mbits/sec                  receiver
This is my Mikrotik configuration:
0 name="wifi-2g" mac-address=48:A9:8A:05:13:9E arp-timeout=auto
radio-mac=48:A9:8A:05:13:9E
configuration.mode=ap .ssid="Dom_" .country=Poland .manager=local
security.authentication-types=wpa2-psk,wpa3-psk .passphrase="xxx"
.wps=disable
channel.band=2ghz-ax .width=20/40mhz .skip-dfs-channels=all
1 name="wifi-5g" mac-address=48:A9:8A:05:13:9D arp-timeout=auto
radio-mac=48:A9:8A:05:13:9D
.wps=disable
channel.band=5ghz-ax .width=20/40/80mhz .skip-dfs-channels=all
The network card on the local computer is an Intel(R) Wi-Fi 6E AX210 160MHz.
Windows shows connection at 1201/1201 (Mbps), distance from the router is about 2m.
maigonis
Re: hAP AX3 poor wifi transfers
Tue Jan 24, 2023 10:18 am
Try multi connection test, aka -P 20 for example.
ffries
Mon Jan 30, 2023 1:30 pm
I experienced the same issue with the Intel AX200 wireless card.
This is a known issue: if you are using dual boot Linux + Windows, you should disable FastBoot in Windows. There are many tutorials how to do it. After disabling FastBoot, I can connect 1200/1200 within 2 meters of the hap AX3 under Linux.
https://wireless.wiki.kernel.org/en/use ... rs/iwlwifi
Users browsing this forum: No registered users and 17 guests
