davidon
Where is documentation for "add" in "/ip address add"
Mon Jan 23, 2023 11:06 pm
The command:
/ip address add
has the "add" keyword, but the wiki doesn't document it.
Link to Wiki for "/ip address"
https://wiki.mikrotik.com/wiki/Manual:IP/Address
Where is the documentation for the "add" keyword in "/ip address"?
Also - fix typo:
In the wiki, it is written:
In case of bridging or PPPoE connection, the physical interface may bot have any address assigned
Instead of the word "bot", it should be written "not", as follows:
In case of bridging or PPPoE connection, the physical interface may not have any address assigned
rextended
Re: Where is documentation for "add" in "/ip address add"
Mon Jan 23, 2023 11:13 pm
For EXAMPLE on EXAMPLE?...
https://wiki.mikrotik.com/wiki/Manual:I ... ss#Example
Luckily you reported that spelling error to us, otherwise how were we to understand?
davidon
Mon Jan 23, 2023 11:57 pm
In general examples are useful though I'm used to having an explanation for every keyword/command which exists in a product.
I thought maybe it exists someplace else, but I understand from your comment that it isn't.
No need to be cynical, I was just trying to help
pe1chl
Re: Where is documentation for "add" in "/ip address add"  [SOLVED]
Tue Jan 24, 2023 12:16 am
The "add" subcommand occurs for every configuration item where a list of values can be assigned.
There is generic documentation here: https://help.mikrotik.com/docs/display/ROS/Console
It shows you that add/remove/edit/print etc are subcommands present in many contexts, and they are not explained everywhere.
At some point you are presumed to understand that "add" will add an IP address. Or a route. Or whatever.
davidon
Tue Jan 24, 2023 12:20 am
Thank you
Users browsing this forum: normis and 105 guests
