keta
reset user counters in ROS V7.7 user manager
Mon Jan 23, 2023 11:49 pm
hello everyone.
I'm using ROS V7.7 on x86 and need to reset counters of all users in user manager.( counters including total download, total upload and etc)
found this code:
/user-manager user reset-counters
or:
/user-manager user reset-counters-all
but no luck.
is there any way to reset all users counters in user manager or for specific user(s) maybe?
keta
Re: reset user counters in ROS V7.7 user manager  [SOLVED]
Sat Apr 01, 2023 2:29 pm
Hi.
I found the answer. for people who are short on attention like me.
ROS V7.7
when creating limitations on Usermanager>>Limitations>> add , there are reset counters interval and reset counters start time drop down lists. you can set your own values.
osxroot
Mon Jul 03, 2023 4:39 pm
Hi keta i’m using usermanager on mikrotik 7.10.1 and “reset counters” on Limitations seems doesn’t work, could you show me your working case?
mistry7
Mon Dec 04, 2023 5:50 pm
is there a solution for reset specific counters?
mistry7
Users browsing this forum: No registered users and 42 guests
