Trick
RB5009 SFP WAN
Tue Jan 24, 2023 12:09 am
I'm trying to setup the RB5009 with my FTTH connection.
I tried creating a vlan as per ISP requirements and selected the sfp-sfpplus1 interface.
Then I created a pppoe client with user and password and selected the vlan as interface.
The pppoe keeps looping through initializing, connecting, terminating, disconnecting.
Assuming everything is fine with the gpon sfp module.
Are there any other steps I should take to properly configured the router?
I just want to make sure th RB5009 is 100% correct so that I can blame it on the sfp module,
I tried two of them, both say they're connected but I can't get the pppoe to connect.
Thanks in advance for any help!
mkx
Re: RB5009 SFP WAN
Tue Jan 24, 2023 2:18 pm
Post text export of full RB5009 configuration. Open terminal window, execute command /export file=anynameyouwish hide-sensitive, fetch resulting file to management computer, open it with text editor, redact remaining sensitive data (usernames, PSKs, device serial number) and post it here between [code] [/code] marking blocks.
Also tell us which exact model of SFP module you're using. ROS is quite sensitive about modules and not all of them work. Compatibility list lists mostly Mikrotik's own modules (and as it can be seen, even those don't work without gotchas on all of MT devices), 3rd party modules are officially not supported - but some of them work just fine. You mentioned GPON SFP module ... those are notorious not to work with ROS devices (except a few models that some users managed to get working).
Trick
Re: RB5009 SFP WAN
Tue Jan 24, 2023 3:31 pm
thanks for the reply.
I tried with a Huawei MA5671A and a Technicolor AFM0003.
Here's my config:
# jan/18/2023 18:20:55 by RouterOS 7.7
# software id = DB48-QCL2
# model = RB5009UG+S+
add admin-mac=2C:C8:1B:FF:94:0B auto-mac=no comment=defconf name=bridge
set [ find default-name=sfp-sfpplus1 ] speed=2.5Gbps
/interface vlan
add interface=sfp-sfpplus1 name=vlan1 vlan-id=1036
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan1 name=pppoe-out1 \
    use-peer-dns=yes user=vodafoneadsl
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge interface=ether1
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
    all wan-interface-list=all
add comment=defconf interface=vlan1 list=WAN
    192.168.88.0
add address=192.168.1.15/24 interface=sfp-sfpplus1 network=192.168.1.0
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid disabled=yes
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-direction=tx filter-interface=sfp-sfpplus1
mkx
Re: RB5009 SFP WAN
Tue Jan 24, 2023 6:20 pm
The config (as far as it goes for PPPoE) seems fine.
Did you see this thread? viewtopic.php?t=172201
Trick
Re: RB5009 SFP WAN
Tue Jan 24, 2023 6:44 pm
Great thanks. I was worried the pppoe config was wrong and that's why it wasn't connecting.
I guess there's something missing in the sfp's config then.
I just had a look at that thread, it looks like the module is working tho.
I can't get it to connect even at 1gbit.
Users browsing this forum: AdamT77 and 110 guests
