stefanpandele
Router doesn't want to route
Tue Jan 24, 2023 12:56 am
I just bought a RB3011UIAS-RM router and full of enthusiasm I started to configure it but after 4 hours I gave up...
I have a pppoe connection with my ISP and their router is connected into LAN1 of the mikrotik router
My computer is connected in LAN2 and my lan will have 192.168.88.0/24
I paste below the configuration and ask you to give me a helping hand.
If I ping 8.8.8.8 within winbox, it is ok but if I ping from my pc, I get timeout.
[admin@MikroTik] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 WAN-DIGI 5
1 ADC 10.0.0.1/32 82.78.103.72 WAN-DIGI 0
2 ADC 192.168.88.0/24 192.168.88.1 bridge 0
[admin@MikroTik] > export
# jan/24/2023 00:18:33 by RouterOS 6.49.7
# software id = UA0K-2K32
# model = RB3011UiAS
# serial number = HDF08JN1xxx
add admin-mac=48:A9:8A:07:FC:5C auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name="ether1 - DIGI"
set [ find default-name=ether2 ] name="ether2 - Mac Mini"
/interface pppoe-client
add add-default-route=yes default-route-distance=5 disabled=no interface="ether1 - DIGI" name=WAN-DIGI password=7YfdeR1Mc3 use-peer-dns=yes user=IF269932330
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface="ether2 - Mac Mini"
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add comment=defconf interface="ether1 - DIGI" list=WAN
add address=192.168.88.1/24 comment=defconf interface="ether2 - Mac Mini" network=192.168.88.0
/ip dhcp-client
add comment=defconf default-route-distance=7 disabled=no interface="ether1 - DIGI"
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=5 gateway=WAN-DIGI
/system clock
set time-zone-name=Europe/Bucharest
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
Thanks in advance!
Reason: Use proper tags: quote to quote, code for code - keep forum tidy
normis
Re: Router doesn't want to route  [SOLVED]
Tue Jan 24, 2023 8:48 am
Your NAT masquerade is configured to be going out from one of the WAN interfaces, but in the WAN interfaces you don't have PPPoE. Add it to the WAN interface list members.
stefanpandele
Tue Jan 24, 2023 9:51 am
thanks a lot. that was the problem!
Users browsing this forum: Bing [Bot], GoogleOther [Bot] and 50 guests
