Dhmellin
CAPsMAN with Two Hap ac2?
Tue Jan 24, 2023 1:14 am
I followed this tutorial https://multilink.us/blog/how-to-setup- ... h-network/
But am not able to replicate the results. I am using two hap ac2 access points, and have ensured local forwarding is enabled (mentioned in an update to the video but not shown). It seems like CAPsMAN is set up and provisions the
Main access point's radio.
I have also tried quickset Home Mesh but I can't see the other hap from the Remote CAP page in either case unless I connect them together with an Ethernet cable.
Ive tried changing the IP of the main router as it seems like the other access point does not automatically join the mesh and gets the default .88.1 IP but does not seem to change anything.
holvoetn
Re: CAPsMAN with Two Hap ac2?
Tue Jan 24, 2023 12:07 pm
Take a look at this one.
Maybe it's more clear.
https://help.mikrotik.com/docs/pages/vi ... Id=1409149
normis
Tue Jan 24, 2023 12:09 pm
How about this one? https://youtu.be/taQ70m0DVYA
holvoetn
Tue Jan 24, 2023 12:10 pm
Not fair.
You made those videos ... :lol:
Dhmellin
Wed Jan 25, 2023 5:17 pm
Thank you for the replies guys, I will attempt them and hopefully get it right this time.
Dhmellin
Thu Jan 26, 2023 6:44 pm
Hi normis, this is the tutorial I followed. There must be some initial setup I am missing to make this work.
Not fair.
Thanks for the link holvoetn. It was easier to follow than the video since I didn't have to pause it but I also didn't get anywhere with it. I didn't see where the guide enabled capsman for the radios so with this I did not even get capsman to pick up the local radios.
My process is:
Open winbox
Connect hapac2_master over ethernet to PC using Neighbors
Factory reset hapac2_master
Reconnect
Default config is loaded
Open CAPsMAN
Goto Configuration Tab
Open config poup
Create cfg1
SSID "WiFi"
Channel subtab blank
Rates subtab blank
Datapah subtab: Use "bridge", local forwarding on
Security subtab: WPA PSK, WPA2 PSK, passphrase "wifipassword" for now
Finish configuration
Goto CAP Interface
Create new interface
All tabs blank except Datapath: use "bridge," local forwarding on
Open Wireless Tab
Goto WiFi Interfaces
Open CAP
Click "Enabled"
Interfaces: wlan1, wlan2
CAPsMAN Addressess: 127.0.0.1
Bridge: bridge
Remote CAP now shows local radios, radios shown as managed by CAPsMAN on Wireless.
Power hapac2_slave with res/wps button pressed
Wait until USR light flashes, hold button until solid, release button
hapac2_slave does not appear in Remote CAP
Does appear if I connect to hapac2_master with an ethernet cable.
karlisi
Fri Jan 27, 2023 9:26 am
Hap ac2 reset button has no CAP mode, as per user manual. Instead you should log in similar to your master router, click on Quick Set, then choose CAP, adjust settings if needed, and save settings.
normis
Fri Jan 27, 2023 9:27 am
All devices have it, just the manual is sometimes too old
Cranberry7254
Tue Aug 15, 2023 9:32 am
I'm having same problem.
1. hAP ax2 as Master
2. hAP ac2 as Slave
Slave does not show up on Master at all (tried number of configurations, tutorials, resets, etc.). Is there something specific about hAP ac2?
I am able to get hAP ax lite working with Master without any problems.
Would be grateful for any pointers. Even if someone will say that ac2 will not work this way.
Here's my Slave export:
# 2023-08-15 08:42:33 by RouterOS 7.10.2
# software id = **ELIDED**
# model = RBD52G-5HacD2HnD-TC
# serial number = **ELIDED**
add fast-forward=no name=bridge
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce frequency=2427 ssid=""
set [ find default-name=wlan2 ] ssid=MikroTik
/caps-man datapath
add bridge=bridge local-forwarding=yes name=datapath1
add name=WAN
add name=LAN
/ip hotspot profile
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=wlan2
add bridge=bridge interface=wlan1
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
/interface wireless cap
set bridge=bridge caps-man-addresses=192.168.88.1 discovery-interfaces=bridge enabled=yes interfaces=wlan2,wlan1
/ip dhcp-client
add interface=bridge
/system note
set show-at-login=no
tangent
Tue Aug 15, 2023 9:43 am
No, you’re not. Your problem is that the CAPSMAN implementations are incompatible between wave2 and older devices. No amount of messing about will get an ac² and an ax² to cooperate in this manner.
Users browsing this forum: gimmo, RBrogen and 60 guests
