kubla36
GPS, CubeSA, 7.7
Tue Jan 24, 2023 3:24 am
Is the GPS feature working on Cube SA Pro ac running 7.7? I have GPS enabled, but it sees no satellites (let it sit outside for an hour with no change-- date/time increment from 1/6/1980, but that's all).
[admin@MikroTik] /system/console> /port/print
Columns: NAME, CHANNELS, USED-BY, BAUD-RATE
# NAME CHANNELS USED-BY BAUD-RATE
0 gps 1 GPS 115200
[admin@MikroTik] > system/gps/export
# jan/23/2023 19:05:35 by RouterOS 7.7
# software id = 90Q5-M1K8
# model = CubeG-5ac60ay-SA
# serial number = *******
/system gps
set enabled=yes port=gps
[admin@MikroTik] /system/gps> print
enabled: yes
port: gps
channel: 0
init-string:
set-system-time: no
coordinate-format: ddmm
[admin@MikroTik] /system/gps> monitor
date-and-time: jan/06/1980 03:21:08
latitude: none
longitude: none
altitude: 0.000000 m
speed: 0.000000 km/h
destination-bearing: none
true-bearing: 0.000000 deg. True
magnetic-bearing: 0.000000 deg. Mag
valid: no
satellites: 0
fix-quality: 0
data-age: 0s
kubla36
Re: GPS, CubeSA, 7.7
Tue Feb 07, 2023 12:31 am
GPS is working in 7.8beta3 for CubeSA.
Users browsing this forum: No registered users and 51 guests
