RickeDz
VPN Slow Speed
Tue Jan 24, 2023 8:08 am
Hi guys, thanks for coming on my topic... I have the following scenario:
1 -> Modem(DMZ to 192.168.1.15) -> MikroTik (DHCLIENT 192.168.1.15 / DHCP Server 192.168.88.0/24) -> Dell Server with Samba Shared Folders on Network
1 -> INTERNET OF THIS NETWORK (SERVER) 300MB Download / 150MB Upload
And on 2ND Scenario
2 -> Modem -> Notebook(Cable)
This 2nd internet has 200MB Download Speed and 150MB Upload Speed
If I put an HTTP File server on the Dell Server and open the port 80, the notebook download a ISO file on the MAXIMUM UPLOAD SPEED of the server (150MB->15Mb/s)
And the Notebook use a software who need to access the files throught samba server the databases files, mdb... etc
And I have try to use PPTP / L2TP / WIREGUARD... to connect VPN with the mikrotik, and When I access the server (\\192.168.88.100) through Windows Explorer, the speed of copy a file it's around 2mb/s...3mb/s...
Have something to do to mikrotik (rb750fr3) on the server network to give better speed's on VPN?
Huge Thanks!!!!
erlinden
Re: VPN Slow Speed
Tue Jan 24, 2023 9:06 am
To start: can you please use the correct notation:
m = millli
M = Mega
b = bit
B = byte
Usually network speed is witten in Mbps (or Mb/s) or Gbps (or Gb/s).
Wireguard should be able to do better, can you share your config?
/export file=anynameyoulike
Make sure to remove any personal information.
During test, what is the cpu load of the MikroTik?
holvoetn
Re: VPN Slow Speed
Tue Jan 24, 2023 10:01 am
I assume you're talking about Hex (750GR3) ?
You are also mixing up various VPN protocols so it is not clear what you are comparing with.
In general:
PPTP will be the fastest BUT AVOID when possible. Obsolete protocol, way too easy to crack.
Wireguard will be next (about 50% of your slowest connection)
Then LT2P
Then OpenVPN
The slowest part of the end-to-end connection one decides the pace.
But as requested, please provide config details and CPU load when running each of those VPN setups.
RickeDz
Re: VPN Slow Speed
Thu Jan 26, 2023 4:46 am
Hi @erlinden and @holvoetn, first thanks for the answers, I will try to answer all the questions here ok?
First the speedtest from the server...
Second the speedtest from the client...
During test, cpu load about 10% or less, because have only one client on this vpn and only the server connected on server network...
File Copy throught windows folder... from the server to local pc... STABLE SPEED around 3MB/s~4MB/s
Same file been downloaded via webserver (http) chrome on port 58080.... STABLE SPEED around 15MB/s~18MB/s
What it's the secret? pleeease haha :(
RickeDz
Re: VPN Slow Speed
Thu Jan 26, 2023 4:50 am
My config file it's here, all default configuration and all firewall rules are turned OFF to test the vpn...
# jan/25/2023 23:27:22 by RouterOS 7.7
# software id = I0WQ-RF5T
# model = RB750Gr3
add admin-mac=B8:69:F4:5D:C9:8E auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    use-peer-dns=yes user=xxxxx
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/interface wireguard peers
add allowed-address=192.168.100.2/32 interface=wireguard1 public-key=\
    "8taHnSY851jklT2Z7ywWBQhkllkjlhjklca7UfCIOkllkC0YnIk71N3nOLEgY="
    192.168.88.0
add address=192.168.100.1/24 interface=wireguard1 network=192.168.100.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat dst-port=58080 protocol=tcp to-addresses=\
    192.168.88.100 to-ports=58080
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=America/Bahia
/tool mac-server
/tool mac-server mac-winbox
RickeDz
Re: VPN Slow Speed
Thu Jan 26, 2023 4:51 am
m = millli
M = Mega
b = bit
B = byte
Thanks for your answer
RickeDz
Re: VPN Slow Speed
In general:
Then LT2P
Then OpenVPN
Thanks for your answer too, sorry guys for my bad english.
nichky
Re: VPN Slow Speed
Thu Jan 26, 2023 4:54 am
what is the max size of MTU ( do-not-fragment ) that u can get across the VPN?
RickeDz
Re: VPN Slow Speed
Thu Jan 26, 2023 4:56 am
I recorded a video and uploaded it on youtube of the case
https://www.youtube.com/watch?v=D3tFkFLiRx0
I think it's better to explain
RickeDz
Re: VPN Slow Speed
Thu Jan 26, 2023 5:02 am
I think the answer it's here on this image, isn't it? sorry I'm starting with mikrotik now...
rahulshakti
Re: VPN Slow Speed
Thu Jan 26, 2023 7:29 pm
There are several potential solutions to slow VPN speed, including:
Connect to a different server: Sometimes the server you are connected to may be experiencing high traffic or congestion, which can lead to slower speeds. Try connecting to a different server to see if that improves your speed.
Check your bandwidth: Make sure your internet connection has enough bandwidth to support the VPN. If you have a slow internet connection, a VPN will likely make it even slower.
Disable features that consume bandwidth: Some features like peer-to-peer (P2P) file sharing or streaming can consume a lot of bandwidth. Try disabling these features to see if that improves your VPN speed.
Switch to a different VPN protocol: Different VPN protocols can have different speeds. Some protocols like OpenVPN and IKEv2 are known for their fast speeds, so try switching to one of these protocols to see if that improves your speed.
Try a different VPN service: Some VPN services may be faster than others, so if none of the above solutions work, you may want to consider switching to a different VPN service.
Check your device and network: Check your device and network to see if there is a problem. Sometimes the issue is on the device or network level and not the VPN service.
It is important to note that some VPN services are not designed for streaming or heavy downloads, and if that is your use case, maybe you need to look into that before subscribing.
RickeDz
Re: VPN Slow Speed
Mon Jan 30, 2023 1:22 pm
I Think it's a samba latency problem... if someone know how to share via another protocol, please help
Users browsing this forum: fadelliz78, holvoetn, memo009525, papabear23 and 47 guests
