sal1
simple bridge configuration on 1100
Tue Jan 24, 2023 11:13 am
Hi all,
I have a small 2011 that has a simple configuration, 1 tagged port and 2 untagged ports and it is working fine.
I wanted to replace it with a 1100 with the same simple configuration but it does not work.
The setting is:
port 1 tagged with vlan4 & vlan5
bridge4 has port 4 & vlan4
bridge5 has port 5 & vlan5
any help appreciated
erlinden
Re: simple bridge configuration on 1100
Tue Jan 24, 2023 11:19 am
What is the expected result and what is the actual result?
Can you share the complete config?
/export file=anynameyoulike
Don't forget to remove any personal information
sal1
Tue Jan 24, 2023 11:52 am
Expected: receive traffic from an ISP trunk that has 2 vlans, and divide it to 2 separate routers. This works fine on the 2011 but does not on the 1100
Actual result: no traffic is flowing for the 1100.
# model = 1100AHx2
add name=bridge4
add name=bridge5
/interface vlan
add interface=ether1 name=vlan4 vlan-id=4
add interface=ether1 name=vlan5 vlan-id=5
add bridge=bridge2014 interface=ether4
add bridge=bridge2014 interface=vlan2014
add bridge=bridge2014 interface=ether5
add bridge=bridge2014 interface=vlan2015
erlinden
Tue Jan 24, 2023 12:01 pm
You might want to consider doing it the bridge vlan filtering way:
viewtopic.php?f=13&t=143620
What RouterOS version are both Tiks running?
sal1
Tue Jan 24, 2023 2:15 pm
Thanks for the hint
I configured according to example1 in wiki:
https://wiki.mikrotik.com/wiki/Manual:I ... ess_Ports)
and all things ran smoothly.
routerOS on 2011 v6.48.6
on 1100 v6.49.7
Best regards
anav
Wed Jan 25, 2023 1:35 am
makes no sense,
First vlans shouldnt normally be used as interface on bridge port ( key word ports, its normally for ports/wlans)
Secondly, you introduce two vlans that are not identified?? 2014,2015
Third you have a bridge names that is not identified?? bridge2014
Perhaps this will work ??????????
add name=SINGLE-BRIDGE { vlan-filtering=yes ( added as last step of config) }
/interface vlan
add interface=SINGLE-BRIDGE name=RouterFOUR vlan-id=4
add interface=SINGLE-BRIDGE name=RouterFIVE vlan-id=5
add bridge=SINGLE-BRIDGE interface=ether1
add bridge=SINGLE-BRIDGE interface=ether4 pvid=4
add bridge=SINGLE-BRIDGE interface=ether5 pvid=5
/interface bridge vlan
add bridge=SINGLE-BRIDGE tagged=SINGLE-EFFING-BRIDGE,ether1 untagged=ether4 vlan-ids=4
add bridge=SINGLE-BRIDGE tagged=SINGLE-EFFING-BRIDGE,ether1 untagged=ether5 vlan-ids=5
anav
Wed Jan 25, 2023 2:28 am
Can you post your config so I can see what a working link looks like please.
sal1
Wed Jan 25, 2023 11:26 am
makes no sense,
you are right.
There is mis-configuration from my side.
Sorry for wasting your time, The 2 methods of implementing vlans worked
Users browsing this forum: ejaka2s, GoogleOther [Bot], Majestic-12 [Bot] and 192 guests
